Question about Freezers
Fridge freezer thermostat
I ve got a zannusi zebf 255 w and i need to change can an please tell me where the capillary from the theermostat is fixed at the back. i ve followed it from the thermostat in the inside where it goes into the inner casing, but god knows where it comess out behind the fridge. please please help curlydave
    President:
  • 1,462 Answers
Doesn't come out anywhere - just push capilliary till it hits end of the tube you are pushing it into
Posted on Oct 09, 2008
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Alarm red light on in my Bosch KGU32124 GB Fridge Freezer. What do I do?
more than likley its the thermostat stoped working,,its the part that tells the compresor to start up and cool things down, change the thermostat first
Jun 24, 2010 | Bosch Freezers
My chest freezer now runs continuously, I presume thermostat at fault. Is this easy to fix I am quite handy wth tools.
Good day,
They do a good job of hiding them, but it should be in the machine compartment near the compressor.
Not too hard to remove, but you must use caution, in removing the long skinny capillary tube that is inserted into the tube that runs into the cabinet. NO, IT IS NOT A WIRE. It carries a small refrigerant charge inside and if broken, the control is ruined.
Note: My experience, is the problem is a small loss of refrigerant charge in 90% of the cases, not the thermostat.
If the thermostat will not shut off, and the unit runs for in excess of 24 hours, the interior temperature should be colder than -10 degrees. Check first.
The purpose of a thermostat is not to turn the machine on, it's purpose is to turn it off.
If the freon charge is low, it will not reach the sensing capillary tube of the thermostat described above.
Dec 22, 2009 | Freezers
Hotpoint fridge freezer icing up freezer and fridge does not work
Does your model have independent thermostats for the fridge & freezer???
If not, could be that you will need to change the Thermostat.
These are not expensive - around £10 if you buy on the Internet.
Easy to fit yourself...just turn off the power, remove the power plug from the wall, then unscrew the 'stat unit from inside near the top of the fridge (some are attached to the interior light) and remove the screw holding the thermostat tube to the rear wall.
Often the thermostat gets a small hole somewhere in the long tube, which then lets all the gas escape, making the stat useless.
You can see these small holes in the pipe if you use a magnifying eyeglass, like the kind Jewellers use.
Nov 17, 2009 | Freezers
Air escaping from my fridge-freezer.
The sound you are hearing is just the circulation of refrigerant through the system. More specifically it is caused by the changes of pressures happening when refrigerant passes through the capillary tube and into the evaporator, changing from a liquid to a gas. This is not dangerous at all.
Nov 13, 2009 | Freezers
Frigidaire FRE196A
you know where you adjust the temperature of your fridge. its a knob with a line that increase in thickness. or it may have numbers written on it. before you replace it. try adjusting that knob to set it to a higher temp. please if your taking the covers off the replace thermostat,, please turn the power off first.
Nov 11, 2009 | Frigidaire Freezers
It quit running and everything thawed. It's got electric going to the dial. plugged it in and can't hear anything running.
The power coming into the fridge goes to the thermostat and when it's time for cooling the thermostat tells the compressor and other components to come on so it has to be the thermostat..Does the light insinde the fridge work? If so i would replace the thermostat and it should fix the problem!!!
Nov 06, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Want to replace thermostat of ge chest freezer fcm7duaww
first of all, switch off your freezer and let all the ice to melt. now snap the capilary with a great force....... don't worry nothing will be damaged beacuse it is the only way to pull the capilary out.............have a nice day :-)
May 14, 2009 | GE Freezers
Candy cpca291ffk fridge freezer
This is due to the failure of the thermostat device..hence its not controlling the temperature..If you are good at electrical appliance repair i can tell u how to fix it...Otherwise i advice you give it for servicing...Let me know what you have choosen..
Oct 18, 2007 | Freezers
Replacement thermostat in chest freezer
in order for the "stat" to sense the coldness of the freezer box it needs to be within the chilled space. it is probably held on by a couple of clips on the underside of the freezer compartment on the evaporator plate.
Sep 11, 2007 | Freezers
Freezers Logo
79 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
