Question about HP Pavilion dv5020us Notebook
Hard Drive What is the largest HDD I can put into my HP Pavilion DV5000? It came with a 120GB 4200RPM drive, and HP support says that's the max for my system, but I'm having a hard time believing them, especially since I saw a reply in this forum to someone else with a dv5000 series system that the response was that they could go as high as 400GB. What are the potential problems that could happen for putting in a hard drive larger than HP says can be used? I don't want to burn up the system or do damage but I'd love a bigger drive if it's possible. Please note, the only option for my product in the categories was dv5020us. Mine's a dv5000z cto (custom order). Specs are as follows: Windows XP Media Center Edition v5.1.2600. Service Pack 2. Bios version F.54. AMD Turion 64 ML-37. Memory: 2.00 GB installed (max: 4.0 GB). This info came from the Help and Support Center's System Information screen.
  • stewlis Oct 09, 2008
    I have externals. I need more space on the internal drive so I don't have to bring the external with me when we're moving back to the US. Going to be without our stuff for about 2-3 months during transition and need to pack as little as possible. Every little bit counts. We are into photography too, so that's the biggest reason for needing more space. Thanks for the thought, though.
  • 50 Answers
Just get an external hard disk man.......they go upto 1 TB
Posted on Oct 09, 2008
PXE-E61 : Media test failure, Check cable. PXE-MOF : Exiting PXE ROM
You gotta a bad hard drive and it's not recognized when the computer is powered up. The ZE2000 uses good old 2.5", 9.5mm(height) ATA/IDE drives and the stock drives are of the slower variety (4200rpm rotation speed) - it's probably easy enough that anyone can get a new one (and a faster one of 5400rpm or 7200rpm) and replace it within a minute or two. Best source for these things is by mail: buy 'em on Amazon or eBay and in general, don't pay over 50 cents per gigabyte or you'll look like a tourist.
HP puts out its service manual online, so I'll just pass along the link (this may or may not be for your exact model, but for hard drive replacement, it's all the same): http://h10032.www1.hp.com/ctg/Manual/c00442578.pdf
HDD replacement is page 110, I believe. Removing and installing a hard drive should take no more than 120 seconds.
Of course, you'll have the load Windows after the installation, and that'll take roughly 60-90 minutes.
Sep 14, 2011 | HP Pavilion ze2000 Notebook
Hi,i hav laptop hp pavilion dv4000,i try on it it doesnt boot. i try to load operating system, it doesnt see the hard drive, i put new hard drive, the same thing happen. And the battery went off when the...
- try going to bios and check if the HDD is detected
- if yes, load default bios
- if not detected, go to HP website and see if there's an option how to reset the HDD
- if resetting the HDD did not resolved it, then you need to replace the HDD
Jun 25, 2011 | HP Computers & Internet
Can i replace the the hp pavilion DV4000 SERIES 80GB (4200 RPM) HARD DRIVE with any 7200 rpm notebook hdd?
You should be able to replace it, but you will need an adapter lead from laptop hdd to motherboard as the laptop hdd will be smaller and you may need a kit to fix hdd into 3.5" bay. Both are readily available.
Feb 13, 2011 | HP PAVILION DV4000 SERIES 80GB (4200 RPM)...
I want to know which memory to buy for my pc. I checked it on crucial.com and it said I could upgrade to 1gb. When I looked inside the cover I saw a 256mb memory chip but could not see how many slots it...
hello, here's a part of the spec from the hp website. It looks like you've got 256mb on board memory and one expansion memory slot in which you can fit a 1024mb card, giving you a max memory of 1280mb (1024+256).
Hope this helps!
nicam49
Hardware
Product Name zv5410US US Product Number PR465UA#ABA Microprocessor 1.8GHz AMD™ Athlon™ 64 Processor 3000+ with PowerNow!™ Microprocessor Cache 1MB L2 Cache Memory 512MB DDR SDRAM (2 x 256MB) at 333MHz Memory Max 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB) Video Graphics NVIDIA GeForce 4 440 Go Video Memory 64MB DDR (dedicated) Hard Drive 60GB (4200RPM) Hard Drive Diskette Drive External USB Floppy Drive available for customers via hpshopping.com or local retailers
Jan 11, 2011 | HP Pavilion zv5410US Notebook
What is the max hdd capacity I can install in a HP ZD8000 laptop?
Your computer uses ATA drives which topped out around 250MB simply because manufactures switched over to SATA drives. It is a pain to change out disks on laptops since you can only have one internal drive. You then have to reload everything.
Here is one I found: Western Digital Scorpio Blue WD2500BEVE 250GB 5400 RPM 2.5" ATA-6 Internal Notebook Hard Drive -Bare Drive
  • 250GB
  • 5400 RPM 8MB Cache
  • ATA-6
I'd consider one of the external USB disks instead to store your data, pictures, etc. You could then put it on your desktop or on a new notebook.
Sep 16, 2010 | HP Pavilion zd8000 Notebook
What's the largest capacity HDD my Toshiba 4300 can support? Also what's the max RAM it can support?
This can support up to 160 GB of hard drive and for the max RAM support it can handle up to 320 MB.
Aug 16, 2010 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
Hard drive replacement
Hi there, I have an HP nx6110 and it had a WD 60GB 4200 rpm IDE, I bought a Seagate 80GB IDE Hdd and it worked fine. The only think you should be careful is to check if you need a SATA Hdd or IDE Hdd, but I think it's a SATA.
Apr 02, 2009 | Fujitsu Computers & Internet
HDD
400GB is maximum supported HDD for your laptop.
Jul 16, 2008 | HP Pavilion dv5020us Notebook
Sata drive will not fit
This is clear that your laptop doesnt support SATA and will support only to the previously used type of HDD..
Thankyou
Jun 17, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv5020us Notebook Logo
120 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
