SOURCE: HOOVER HNMF2605A FRIDGE\FREEZER
main stat? what is a main stat?... do you mean thermostat?...that is the thing that controls the compressor to stop if its already cold inside the compartment. or your compressor could have been hot wired already. has anyone repaired your ref before?
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
i had the same problem the sensor starts at the back of the pcb and snakes its way dow the back of the fridge into the freezer conpartment i ordered a new sensor thinking it was a temp sensor but turned out to be a defrost sensor compleat and utter hassel to fit due to the expanding foam i had to eventualy cut the block off that conects to the pcb and then reconecting it once i got the cable through the foam first 2 days seamed to work fine while there was nothing in it as soon as i put food in it again the fridge started to freeze everything again then about a week later it still ices up at the back the fridge but doesnt seam to freeze the food so much now so still unsure about it all
btw it was the exact same model and before i changed the sensor the light and the super light used to flash on and off
