Question about Compaq Evo N610C Notebook
Hello! i want to upgrade the ram of my laptop to 1gb.my memory right now is 2x256md ddr266.then i go to the website of hp and look for the applicable memory and i saw there the maximum applicable is 1024mb ddr266.can i make it ddr333 insted of 266?it there's posibility it will harm my computer when i change it to ddr333??guyz help me......
I am using 2GB of ram in my system, PQI DDR400 1GB * 2 memories. It runs fine, except when using external usb drive, system will hang when copy large file.
Posted on Nov 18, 2008
  • 71 Answers
I think the best solution to your problem would be either to go to www.crucial.com or www.tigerdirect.com . They both have memory configurator tools that will make sure the memory that you are purchasing is compatable with your laptop. That is your safest way to know. I myself prefer tiger direct, they seem to have the lowest prices. the link below will take you right to the memory configurator. If the DDR333 is an option it will let you know. Hope this helps! :)
http://memoryselector.cnetchannel.com/tigerdirect/
Posted on Oct 09, 2008
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Aug 23, 2013 | HP Pavilion ze2000 Notebook
Upgraded ram 1gb wont boot hp 510 mobo 30C4
If you added another 512Mb RAM to increase the RAM to 1Gb then the new 512Mb memory stick could be incompatible with the original 512Mb or it could be faulty.
Use RAM that is same make and speed as the original RAM.
Remove both RAM and just insert the new 512Mb into your laptop and see if the laptop boots up, if not then the RAM could be faulty.
Mar 02, 2013 | HP 510 Notebook
My ram is 256 and how to upgrade to one gb ecs p4vmm2 intel r celeron
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=24&LanID=0
Your mainboard supports:
2 DDR DIMMs
Supports DDR266 / DDR200
Max. 2GB
You can easy add 2, 1gb modules.
I recommend 2 gb ram.
Good luck
Dec 02, 2012 | EliteGroup ECS P4VMM2 Supports Intel...
What is the maximum Ram supported bu Intel 1.86
Your system has a maximum capacity of 2 GB of SDRAM - 266.0 MHz
Jan 05, 2010 | HP Pavilion dv1000 Notebook
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
Memory up-grade
you can go max 2GB (1GB each) DDR333 PC2700.
you have to reset the bus rate to match the RAM speed.
if you stay with DDR266 then you don't have to reset the bus rate
Nov 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
My PC won't work with 3Gb of RAM
THE RAM CAPACITY OF THIS BOARD IS
DDR266/200, Max. capacity of system memory: 3GB
- DDR333, Max. capacity of system memory: 2GB
- DDR400, Max. capacity of system memory: 1GB
Oct 03, 2008 | Asrock K7S8X-R3 Motherboard
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
How much ram can i install on a hp compaq d220mt?
Laptop Computer Memory Desktop Computer Memory Printer Memory Memory Applications All data processing and execution takes place within the memory module(s). The program's directions are replicated into memory from a hard drive, external drive or from a network. The processor then extracts the directions from the memory and puts it into the circuit for analysis and execution.
Memory is so important that it cannot be wasted. RAM is allocated by the operating system and programs, and then released when not needed. Errant applications can grip RAM and not release it, which results in a diminishing amount of memory available as you load and use more programs.
If you could actually look into memory, you would be astonished. By watching how much and how quick data and commands are written in and out of it each day, you would realize it is a marvel that it works so we
UpgradeComputerMemory.com is here to help you speed up and breathe new life into your computer by adding more RAM memory! We have hundreds of relationships with different manufacturers and carry all major computer memory brands. This includes Dell Memory, HP Memory, Samsung Memory, Micron Memory, Toshiba Memory and many, many more. We can cut through all that computer jargon and provide you with the part that will work each and every time. Our 100% guaranteed compatible RAM memory upgrades are available for more than 21,000 different computers, laptops, servers, printers and other electronic device.
Jan 15, 2008 | Computers & Internet
Compaq Evo N610C Notebook Logo
90 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
