Question about Water Heaters
Hot water not heated as usual ?
Over the last week my hot water has not been the usual temperature. Actually it has been cold a number of times in the past week, particularly in the evenings (ie: evening shower)
There have been no adjustments made to the thermostat on the cylinder and the hot water fuse has not tripped out.
The cylinder is approx 5 years old
  • 1 more comment
  • davedixon Oct 09, 2008
    Thanks for the help. I will get an electrician in to look at it. ( Electric Hot water heater )
    Bugger though, as now I have no hot water?
    Thanks again
  • nazio Oct 19, 2008
    hi,
    ive got a rheem 101250 water heater and it suddenly stopped heating after i had a shower. this has never happend before and i really need help!
    its about 14 years old
  • JodyTheQueen Oct 24, 2008
    We just installed a Stiebel Eltron 24 heater several months ago - have had problems since with getting only lukewarm water. installer has adjusted it 3 or 4 times, and it still is not functioning properly. They are going to install a new one to see if this corrects the problem. I surely hope so!!!
    Scholar:
  • 121 Answers
This could be one of your elements are bad and now that the weather is cooling down so is the water table. If you have a gas heater your thermostat is becoming weak and/or there is settlement on the bottom of the tank and will need to be drained while heater is off to remove settlement. The same with an elec. heater one of the thermostats could be bad and not allowing the heater to recover fully also again settlement in the tank can be a factor.
Posted on Oct 09, 2008
How and where does the water go in
The cold water enters the top, but the water is not released into tank at the top. The cold water goes through a "dip tube" This takes the cold water to the bottom of the tank. If you dip tube fails, or breaks, your faucet temperature will slowly drop as you use hot water (vs giving you 60% of tank at full temperature before temperature starts dropping) In normal operation, the cold water is released near bottom of tank, the hot water rises to top, and comes out of the top of the tank.
Jan 27, 2015 | Water Water Heaters
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Hot water varies
I do not know how old this unit is or what model but many water heaters are not sophisticated enough to measure the temperature, but heat based on water flow and temperature rise. To start, tankless water heaters turn off every time you turn the hot water off. Lets use an example. You use the facilities, wash your hands then turned off the water and take a shower. You will bring the already heated water (from washing your hands) from the pipe up to the shower. Then the cold water that comes into the pipe from the reactivation of the water heater comes up the hot water pipe with warm then hot water just behind.
If this is not your problem, keep reading. Every unit I have been called to see were installed wrong. Check your installation manual to see if the problem with the system started with the contractor.
First, check the temperature of the water from the heater. If it is too hot and you are mixing too much cold water in, the unit will turn off because there is not enough water flow to keep it running.
Second, turn off the valve at the water heater and turn on the hot water at a faucet. If the water does not stop running, there is a "plumbing cross over" usually caused by a failing pressure balance valve in a shower.
Third, if the unit has not been serviced, go to bosch-climate.us to find a tankless water heating professional in your area. Totally Tankless LLC
Mar 14, 2014 | Bosch & Tankless LP Hot Water Heater
Tank full of hot water,faucets deliver only cold,water trickels into tank with rapid intermittend pump action
1) Copy following link:
2) Add comment with clear description of water heater, fuel type, and pump?
Is this a pump problem or water heater problem?
Is this a water well pump?
Are you getting good stream of cold water at tap?
Which water heater do you have?
Is the heater new?
Or older heater that stopped working.
Dec 27, 2012 | Atwood 10 Gallon Gas/Electric Water Heater...
I have a model number 101160 manufactured in 1994. When showering I am using LESS cold water to maintain a reasonable showering temperature. If a tempeature adjustment is required, how do I adjust the...
Water heaters by Rheem have not changed that much over the years. the link below will give you some good information about electric water heaters in general. As water heaters age, the heating element will lose efficiency due to deposits and general build-up of minerals in the tank. Turning up the temp may not be a good idea since the problem is actually caused by a coating on the element. Also make sure that cold water is not bleeding into shower valves thru other single lever faucets. While shower is running, listen to and feel the water lines connected to sink faucets in other rooms for water transferring thru valve. You can actually hear water running at faucet while shower is on if faulty. If other vaucet valves are leaking thru, repair those first before you do anything to the water heater as that is cause of loss of hot water. Good luck.
http://www.rheem.com.au/images/pdf/owners_dom-elec_121996C_0707.pdf
Jul 18, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water turns cold very quickly
I had the EXACT same problem (installed my tankless last winter and worked fine, now this summer it fluctuates, have to turn the shower completely off and then on again to get any hot water and then it only lasts for a couple of minutes!) Argh - it is frustrating!
Here's what I found: the demand for hot water is lower during the summer (hot) months because the "cold" water coming in is already quite warm. You don't need as much hot water to make the shower temp comfortable. SO, my tankless was shutting off due to low flow demand. I've removed the flow restrictor from my shower head and it helped alot but didn't completely solve the prob. Next step is what has been recommended to me by several people but is much more expensive - change the pressure valve on your shower to a temperature valve. Or just wait til winter and it should work ok again :)
Jul 06, 2010 | Bosch & Tankless LP Hot Water Heater
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Hot water lasts half the time
How old is the heater?
It may be something as simple as just needing to flush the tank to remove any sedemints....and hopefully so because this is the easiest/cheapest thing to do.
If this is not the case go ahead and remove the heating elements and check for wear. Replace them if necessary. I would also replace the thermostats that accompany each of the elements.
Checking and replacing both of this requires you to drain the tank completely and should be close to $25 total....last time I checked.
Apr 27, 2009 | General Electric Water Heaters
Whirlpool temp control on electric water tank
Most electric water heaters have 2 heaters - an upper and a lower, each with it's own thermostat. These are readily accessible by removing the screw covers on the side of the tank. Careful - the thermostats have 240VAC on the terminal screws (unless you have a small 120VAC heater) if the circuit breaker or fuses feeding the heater are still on - turn them off before proceeding. After removing the two screw covers and pulling back the insulation you will see temperature (screw) adjustments for the upper and lower thermostats, with a temperature indicating pointer attached to each screw. Set both thermostats to 125 degrees or so. Push the insulation back in place, replace the covers and turn the circuit breaker back on that feeds the water heater. You should have warm water within 15 minutes and hot water within a hour or so.
If the water still does not heat, then you have to troubleshoot to find the problem. With a voltmeter determine if 240VAC is actually getting to the water heater. Remember, the upper element has priority over the lower element, and if the water is cold, the upper element will try to turn on and this locks out the lower element (only one element is allowed to heat at any given time). The lower element comes on ONLY after the upper thermostat is satisfied. Therefore if the upper heating element is burned out you will never get any hot water. If you suspect this, TURN OFF THE POWER TO THE HEATER and take a resistance check of the upper element.
Nov 16, 2008 | Water Water Heaters
On-Demand Water Heater
An on-demand, or tankless, water heater is a system for heating water as it passes through the pipes, usually very near the point of use. Traditional tank water heaters bring the water to approximately 140 degrees Fahrenheit (60 C), in order to ensure the water supply lasts long after the heater turns off. Since this is obviously far too hot to be pumped out of a shower of faucet, cold water is added to the mix in the pipes. Coupled with the loss of thermal energy over time, the average tank heater has an efficiency of approximately 80%. On-demand water heaters have a number of advantages over their tank-using counterparts. While tanks often degrade over time and begin leaking, the apparatus used in an on-demand water heater is much less susceptible to the burdens of age, and will often outlive the house they're installed in. The amount of energy used is a fraction of that used in a tank water heater, due to increased efficiency and a much smaller window during which a heating source is in use. While tank hot water heaters can, and often do, run out of hot water after a number of showers, on-demand heaters provide a never-ending supply of hot water, ensuring that warm water is always available when needed. A tankless water heater can cost between $500 and $1500, and they most commonly use either electric or natural gas energy to heat the water. Most mid-sized households report an energy savings of approximately 25-45% for a gas or propane heater, and up to 50% with an electric heater, over using traditional tank heaters. Water is usually set to a maximum temperature of 120 degrees Fahrenheit (49 C), though many heaters allow for custom setting of the maximum temperature via remote control. Outflow rates range from 8-14 gallons (30-53 litres) per minute. Installation for most tankless water heaters is incredibly easy, involving simple plumbing. In the case of electric heaters, all that is required for a fuel source is to plug the heater into an outlet and begin heating your water. Some modern on-demand water heaters can incorporate a solar preheating system. This system uses a traditional solar heating system and tank to bring the water nearer to the desired temperature, saving substantial energy use in the final on-demand heating. A solar preheating system costs between $500 and $800.
Aug 27, 2008 | Stiebel Eltron CK20E Electric Tankless...
Water Heaters Logo
575 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
