Question about Monster Cable MPA3250SS 3-Channel Amplifier
Have a trio of Hafler 9505
Same issue :static on one channel then goes down for the count . All three work same way. Worked great for years, bought new.
Thx
George
  • 1,512 Answers
Hi George
Not 100% sure about your exact problem you have asked about. . Is it that all three amps go down simultaneously, or has each amp failed in the same way over time? If all are presenting this problem together then I would suspect a preamp problem, pushing DC voltage to the power amps. If you could please confirm this.
Static sounds are generally created by a failing component, usually a transistor or capacitor going leaky and allowing incorrect DC voltages to pass and upset the operation of the circuit. In turn this is firing the protection circuit, causing the amp goes down for the count. These sorts of problems can some times be easy, and then other times difficult to find. Generally, the best approach to fault finding this sort of problem is with localised alternate heating(hair dryer) and rapid cooling with CRC Freeze Spray. It is the best way to find isolate intermittent parts failing in this manner. Then you know what to replace. If you are not familiar with board level repairs, this may be a job for a HiFi specialist service guy to fix for you. Let me know is you need further assistance. Cheers.
regards
Robotek
Posted on Oct 13, 2008
When i turn it on it says trio stealth g2 and stays there and won't turn the rest of the way on.
Perhaps the HARD RESET PROCESS can help you, Merrill. I've posted my suggestion as to how it's done HERE. ( http://www.fixya.com/support/t25341481-trio_stealth_new_when_power_goes ) , so you may findt that information useful.
I've had good success with HARD RESETTING when trying to correct errors like forgotten password, or forgotten lock-patterns. However, I've had a Trio Stealth G2 that displayed the SAME problem as yours, Merrill, and it would NOT respond to ANY attempts at resetting. I tried every combination I could : pressing volume down (-) and power; volume UP (+) and power; volume UP & DOWN (+ AND -) and power. It refused to boot. But since the case and the screens were in great shape, I went on Ebay and bought a Trio with a cracked screen, swapped the motherboard from THAT tablet and it worked perfectly.
Final caution, though: ask the Ebay seller to guareantee the physical condition of the ports and other controls on the unit before you buy it. Remember you need a working motherboard.
Best of luck to you, Merrill!
Mar 13, 2015 | Trio Stealth G2 7 inch Tablet with 8GB...
How do i turn on the trio t2810c
Just called customer service about this. With the screen unlocked, press the button on the front and hold it down for 5-10 seconds until a power down window appears on the screen. Double tap the screen to turn off the player. Repeat to turn the player back on.
Dec 23, 2011 | Mach Speed Trio Audio Players & Recorders
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Hafler 9505 amp, has noisy output in mono.
Hi Don,
When you bridge the outputs , do you connect only to the ( + ) speakers terminals for your output. This is what the manual says to do.
Let me know
Scott
Apr 07, 2009 | Monster Cable MPA3250SS 3-Channel...
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
Hafler power amp has one side out. Would like local repair.Series 9300.Approx.10-15 years old.Not used much.Second time to blow.Runs 4, 8om speakers including 2 bose 802,s (no bose controller or eq in...
just discovered same problem with my Hafler DH-200...right channel out but no obvious problems inside (no loose/burned wires, components, etc). Driven by Hafler pre-amp, but definitely power amp problem.
Sep 03, 2008 | Audio Players & Recorders
I have a RCA Tv i bought several years ago and up until now it worked great. But it turns itself on and off and switchs through the channels on CATV before shutting down.
the push button switches are bad. you need to have the switches replaced to fix this common problem. the switches get corrosion and start making contact themselves with out being pushed by you causing all kinds of problems.. Your power and channel up and down switches are obviously the ones going bad first.
Aug 02, 2008 | Televison & Video
Hwy pre-programmed frequencies
Unfortunately, I think this is a common problem with these radios. I have a brand new BCT8 and it started to not receive anything on the pre-programed highway patrol after using less than a month. Unfortunately the best bet would be to contact Uniden which they will probably tell you to reload the firmware (which won't solve the problem) or send it to them to fix.
Apr 13, 2008 | Uniden BCT8 Base Scanner
Monster Cable MPA3250SS 3-Channel Amplifier Logo
234 people viewed this question
Top Monster Cable Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Monster Cable Audio Player and Recorder Expert? Answer questions, earn points and help others
