Question about Compaq 7500 17" CRT Monitor
Monitor user controls display on the screen
Monitors user control comes automatically on the screen and do not go. they change the settings automatically and i dont have any control over it.monitors user control comes automatically on the screen and do not go. they change the settings automatically and i dont have any control over it.
  • 65 Answers
Simply change front pannel microswitches(menu,+,-,select)
Check drypoints
replace 5v reg
Posted on Oct 10, 2008
How do i stop my on screen display (osd or menu) from automatically coming on and changing monitor settings when no buttons are being pushed.
Monitor settings shouldn't change automatically, by any means! Now the proble is to find why this happens.
If you are using windows, run it in safe mode and verify if still have the issue.
Eventually you should test it on another computer, might ask help of a friend; it should take just some minutes.
If you detect issue on another computer it is some electronc problem of your controls and shoudld find a way to repair your monitor.
May 03, 2015 | ASUS VE247H 23" LCD Monitor
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Rotate screen back to normal
Feb 23, 2013 | Gateway Computers & Internet
My Samsung n120 screen is displaying only vertically - how do I go back to horiz display?
Feb 15, 2013 | Samsung N120-12GW Netbook
Acer tablet troubleshooting
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish. Hope this helps
b>
Jan 14, 2013 | Computers & Internet
Change screen orientation
b>
Dec 14, 2012 | Dell Computers & Internet
Menu bar appears automatically in front of monitor and automatically uses it.
My SAMTRON monitor 56V is having a problem now..
The control menu of monitor settings which will appear
when the monitor control panel is pressed(Brightness,Contrast....) is coming frequently at my monitor without activation...
Now when the monitor is turned on, the control panel will come,and will not go even if we change the settings..
The control panel is switching between the CONTROL LOCK and UNLOCKED mode during each 5 seconds....So now I cant see anything on my screen
at the middle of the screen due to this overlaying settings panel.
I is giving the same effect as the Menu key is pressed in the panel..(exit,-,+,Menu).
This problem started some 2-3 months before..
Today I hav put some etylene cleaning solution through the gaps to clean from dust... still no change...
If somebody having a remedy please help me..
Sep 11, 2010 | Computers & Internet
I have a samsung crt 15'' monitor display is coming on the half of the screen
Dear User,
You can adjust the Display from the Front Pannel Controls on the Monitor.
Use these buttons to make the display to come up with full screen on the monitor
You can also sort such problem by setting the screeen resolution in Display Properties in Windows upto some extent.
Thanks
Jan 24, 2010 | Computers & Internet
Compaq presario 2127AD
Flickering may b due 2 ur Display configurations so u may also use some Display software or u may manually correct it.
Properties>Settings>
1. adjust ur screen resolution
Change the refresh frequency for your monitor To change the refresh frequency for your monitor
  1. Open shortcutcold.gifDisplay in Control Panel.
  2. On the Settings tab, click Advanced.
  3. On the Monitor tab, in the Refresh Frequency list, click a new refresh rate.
note.gif Notes
  • To open Display, click Start, point to Settings, click Control Panel, and then double-click Display.
  • The default refresh frequency setting is 100 Hertz, although your monitor may support a higher setting. Check your manufacturer's documentation for information regarding the settings your monitor supports.
  • A higher refresh frequency reduces any flicker on your screen, but choosing a setting that is too high for your monitor can make your display unusable and cause damage to your hardware.
  • Changes to the refresh frequency affect all users that log on to the computer.
Jun 03, 2009 | HP Compaq Presario V3000T Notebook
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
