Question about Plumbing
Valve steam cybercafe uploading from server
Ok here it is...I'm the owner and operator of pro gamerz zone llc of san pedro ,ca we have a small cafe of 27 pc's
got valve going 600gb on my new 1tb heres the problem.
its slowly uploading into one pc at a time .
at this point my t-1 shouldnt have any difference on the transfer rate -right?ok
each of my pc's are 320gb.built for gaming my cpu is AMD50002.6ghz dual core.with Nvidia dual DDR2 800.
HD is a saphire 1010 what transfer rate should I most likely be at?with cat 6 cables
  • 19 Answers
SOURCE: slow file transfer
What is your connectivity to the SAN? fiber or iSCSI? Have you checked the management tools to see if there are any errors on the data paths? If using iSCSI and the SAN and server are in the same network segment, make sure the default gateway is empty for the iSCSI connection. Look at the routes on the server to make sure the traffic is not leaving the subnet through a router and back to the SAN, and vice versa. If fiber then you'll have to use the tools given to check for errors. Ken
Posted on Aug 15, 2007
SOURCE: really disappointed with dual core
You can buy a 3.02 pentium 4 processor and need not change any thing else. On the other hand try changing your hard disk with a one with smaller capacity such as 80 GB make it primary with the windows partition not exceeding 15 GB . Make this drive (80 GB )primary and other one secondary.Increase the virtual memory size of your system and for sure you wont need to buy any thing or be depressed anymore.
Posted on Oct 10, 2007
SOURCE: nvidia nforcennetwork bus installation disk #1
I have encountered the same problem with a repair to XP PRO Setup - repair due to a virus, where I didn't want to reinstall from scratch because of the programs that were already installed on C drive. The quickest way to circumvent is to hit Cancel (ensure you have a USB or PS2 mouse - wireless will freeze) repeatedly when provided with this prompt. You will receive other error messages prompting for other things later the process. With hitting Cancel at all of these prompts, Win XP Pro installed fine, and I was able to re-install the latest drivers for the motherboard and video card after Windows XP booted up.
Posted on Apr 27, 2009
not you
  • 158 Answers
SOURCE: Problem for Acer Aspire M1641- PC Desktop
Hi I looked at your cards spec's its calling for a power supply of min 350 Watts,so I'd try replacing that.
here are your Spec's
GPU Clock MHz The main attributes of the GPU are the core clock rate, which typically ranges from 250 MHz to 1200 MHz in modern cards. 589 MHz Shader Clock (MHz) The number of pipelines (vertex and fragment shaders), which translate a 3D image characterized by vertices and lines into a 2D image formed by pixels. 1402 MHz Stream Processors Through the use of stream processing, computer benefit from the ability to transparently access a large number of 'cores' (or, computational units) on a chip without having to separately manage each and every one of them along with their associated busses, memories, I/O, etc. 16 Bus Type N/A PCI-E 2.0 Performance N/A Standard Memory Interface Bus (bit) The bit data rate between memory and the GPU. 64 Memory Type VRAM was typically based on DDR technology. During and after that year, manufacturers moved towards the vastly superior DDR2, GDDR3 and GDDR4. DDR2 Memory Size (MB) the video card will have its own video memory which is called Video RAM or VRAM. The VRAM capacity of most modern video cards range from 128 MB to 2.0 GB. 512 MB Memory Clock (MHz) The memory clock rate in modern cards are generally between 400 MHz and 2.4 GHz. 800 MHz Microsoft® DirectX® Support The standard for today's PCs and next-generation consoles enables stunning and complex effects for cinematic realism. NVIDIA GPUs offer the most complete implementation of the Shader Model feature set-including vertex texture fetch (VTF)-to ensure top-notch compatibility and performance for all DirectX applications. 10.1 Shader Model Support Enables stunning and complex special effects. Next-generation shader architecture delivers faster and smoother gameplay. 4.1 Open GL Optimization and Support Ensures top-notch compatibility and performance for OpenGL applications. 3.1 Minimum Power Requirement (Watt) This is the minimum power supply wattage requirement for the graphics card to perform properly. 350W Cooling Fansink Sometimes known as an active cooling device, a small electrical fan which drives air across a heat sink and as such will generate a small amount of noise. It is more effective than a heat sink alone at cooling. √ ROHS The RoHS Directive stands for "the restriction of the use of certain hazardous substances in electrical and electronic equipment". This Directive bans the placing on the EU market of new electrical and electronic equipment containing more than agreed levels of lead, cadmium, mercury, hexavalent chromium, polybrominated biphenyl (PBB) and polybrominated diphenyl ether (PBDE) flame retardants. √ Profile Some graphics cards have the capability to swap out the current bracket to make it compatible with low-profile computer systems that require a lower bracket card. Low PhysX Technology N/A √ CUDA Technology N/A √ Dimensions (Metric) N/A 16.8 X 6.93 X 1.9 Max Resolution Analog Maximum Screen Resolution indicates the maxiumum possible sharpness and clarity of an image that a monitor can display, measured in number of dots (pixels). 2048 X 1536 Max Resolution Digital Maximum Screen Resolution indicates the maxiumum possible sharpness and clarity of an image that a monitor can display, measured in number of dots (pixels). Hope this has helped and good luck,don't forget to rate...;-} 2560 X 1600
Posted on Jun 28, 2010
Testimonial: "ok thanks for ur help i will try to replace p/supply..."
  • 2072 Answers
SOURCE: nss4000 with home computer quad
Your speed is going to be limited by your slowest component. Most cables you buy in a store are really cat 5e which will do 1000Mbps. If your getting 11MBps (~100Mbps) then something in your network is running at 100Mbps. Assuming your going from Computer -> Router -> Nas
Computer needs a 1Gbps NIC in it, you need at least a cat 5e cable to router, router needs to support 1Gbps bandwidth, cable from router to nas needs to be at least cat 5e and your nic on nas needs to support 1Gbps as well.
So check the spec's on each device and replace the bottleneck because I doubt you can find regular cat 5 unless you tried really hard :)
If you can't find the specs comment back with all three model #s
Posted on Aug 17, 2011
I have a viking pro 11.6. how do i upload pics from microsd card to tablet.
You will need a card reader for USB to do this.
Embroidery Services
San Diego, CA
Jun 13, 2016 | Sewing Machines
My cafe manila 8.6.6
how to add workstation on my cafe server
Nov 19, 2012 | Cafe Manila Cyber Cafe Management Standard
Handy cafe clients could not connect to server. i manually configured the server ip and they are now visible to the server. however ither server cannot control the clients
I am sick of my handycafe server keeps changing its ip addres.....i have to reconfigure from each client every can i just change my handy cafe server ip address......?
May 22, 2012 | Computers & Internet
When i load cyber cafe pro 6 server, it says " port 15346 blocked or unavailable". i have opened the port but still not working. help please
When i start my Cybercafe PRO Server it gives an error messge " Port: 15346 appears to be blocked. Can somebody help me how i can open this port?
Aug 25, 2011 | Computers & Internet
Hi, I have a Cafe Chic coffee/expresso/cappiccinno maker that has not been working properly. When I try to make coffee, the water that is suppose to travel through the filter and coffee grains ends up...
obviously you have leaking steam valve, use my recipe for rearing it:
you should take out the knob first, than you try to disassemble the SHAFT of valve from the valve body, in this types(small espresso coffee machines) usually producer use conical valve, without seals she close metal to metal, when you get out the SHAFT you will see one line on the conical end. for repairing it will be enough to visit one metal workshop where they will take a small amount of brass from end and polish it. then you put it back and work again with your machine. During assembling valve change 2 o rings and put one fitting 1/4'' to block the shaft coming out.
PS: notice you only polish the SHAFT , don't let them to short the more than 0.5 mm
Mar 03, 2011 | Espressione Cafe Chic 1377
.the main server does not
pano ko po ma upload ulit yung cafe manila ko kasi na dlete po sa server
Jan 04, 2011 | Cafe Manila Cyber Cafe Management Standard
I m having an cyber cafe i want to install the software from net which helps when client before login use the name and surname as there login id and password
Use HandyCafe - Internet Cafe Software - FREE! Ates Software released HandyCafe Internet Cafe Software for FREE all over the world. Why would you pay if you can use the best Internet Cafe Software for FREE? Sign-up now and start using HandyCafe Internet Cafe Software now in your Cybercafe. AND ALL FREE..!
follow the link and download 100% free
Apr 23, 2010 | Microsoft Windows Vista Ultimate Edition
Where is the isuzu crosswind airconditioning sale parts center in manila?
Isuzu Motors America, LLC
1400 S. Douglass Road, Suite 100
Anaheim, CA 92806
(714) 935-9300
Owner Relations Inquiries:
Write Us
Owner Relations
Anaheim, CA 92806
Call Us
(800) 255-6727
Hours: 6:00 a.m. to 5:00 p.m. (PST)
Monday to Friday
Dec 21, 2009 | Heating & Cooling
May cafe mate server have bug, the problems describe this way, if the timer start in cafe mate server it counts down it good, but if the remaining time is 1min, the client of the cafe mate server will...
Disable the task manager...
Because they will close the cafe mate in the process thats why it will disconnect to the server...
you disable/enable task manager in group policy tool.
May 06, 2009 | Microsoft Windows Server Standard 2003 for...
Plumbing Logo
105 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
