Question about HP LaserJet 4350dtn Printer
HP laserjet 4350 DTN Folding corners
We have a 4350 dtn which is folding the pages regularly on the printouts, the printer is then printing over the folded pages. This is making for a very messy print job.
ANy suggestions on fixing this.
thanks
Nigel
We have problems in printer hp laserjet after replace formatter it work one week .after one week no display and make fashing leds ready data , attention
Posted on Oct 11, 2009
  • HP Expert
  • 141 Answers
Teflon coating on heat roller in fuser is coming apart. replace the fuser. also check to make sure the paper tray is set to the correct size. this means pull the tray out, remove all paper, look inside to make sure the arrow is pointing directly at the correct media size you are using i.e. letter or legal or whatever you are using. Good Luck! please rate this carefully.
Posted on Oct 11, 2008
My printer HP LASER JET 5200 DTN shows "Ready" on the display but it doesn't print, how can I fix this?
First thing you need to do is establish whether the print engine itself is at fault, or not.
From the relevant printer front panel menu, invoke printing of one or more of the available reports (configuration, font list, etc.); do these print?
If the reports print OK, try to send some plain text to the device.
On a Windows system, you could do this by using the DOS copy command in conjunction with an appropruate net use command to redirect LPT1: to the (USB) port associated with the relevant Windows printer instance.
Jun 02, 2015 | HP Office Equipment & Supplies
Hp laserjet 4300 dtn tray one pickup
Yes,
Adding the duplex attachment makes the TN a DTN nothing different in the firmware of the printer.
Feb 05, 2013 | HP LASERJET 4300DTN Q2434A LASER PRINTER...
For the HP 4350 laserjet DTN what is the error code 50.5 fusion error tell me. Is it an easy fix?
You need to replace the fuser lamp (or ceramic fuser) and the thermistor.
If you can get the replacement parts, it's an easy fix.
Nov 17, 2010 | HP Office Equipment & Supplies
Have a hp laserjet 4350 network printer and have select print on both sides check on the printer preferences and in the finisher tabs. but still doesnt not print on both sides.
This would have to be a 4350DN or DTN model to do automatic duplexing. I would make sure you have one of these 2 models. Depending on what driver was loaded the duplex option may show up, but if the printer does not have the duplex option and the associated firmware then it will not duplex automatically.
This is the only thing I have seen that would cause what you are describing.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 30, 2010 | HP LaserJet 4350 Printer
HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Jan 05, 2010 | HP LaserJet 4350dtn Printer
HP laserjet 2430 dtn little typed letters print on the left side
Probably a bad FUSER. The teflon is probably worn off.
Also take out the toner and move the drum cover aside to look at the drum..It should be clean.
Feb 17, 2009 | HP LaserJet 2430dtn Printer
HP LJ 4350 paper folding problem
It could be either the paper feed assembly, part # RM1-0012, or the registration assembly, part #RM1-1098. These parts can be bought at TSAworld, phone # 1-800-633-6626
Aug 08, 2008 | HP LaserJet 4350 Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
http://www.printertechs.com/tech/repdef/ruler2200.php
Jan 05, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 4350dtn Printer Logo
610 people viewed this question
Ben Johnson
