Question about SVA-USA VR 17 17" Flat Panel LCD Monitor
SVA 17 inch black LCD monitor
The screen chacks how do i fix this?
The color gray and purper squar color
Posted on Nov 09, 2008
My monitor has power but the screen does not have a display no matter what control buttons I push
When i plugged in my sva lcd monitor it was all black but the green light was on,so i reached around the back and tightened up my cords and it came on :)
Jan 14, 2012 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
My screen is green I cant find the menu key on my sva monitor
You need to find menu button - it's got to be there somewhere. If you do find it, go to the "tools" menu (show a wrench and screwdriver), then select the "RECALL" option. Press then right and/or left arrow on that option. This fixed same problem on my SVA Monitor
Good Luck
Nov 19, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Display or power issues with my 17'' LCD screen (SVA LCD #7500L )
Check the high voltage ballast transistor.. see if one of them is burnt... If none.. it could be overheating when supply with current. The ballast transformer supply high voltage for the backlight inverter..If these were overheating then the supply voltage for your monitor will be unstable.
Check also the backlight inverter (cold cathode light) if it is busted.. the function of this backlight inverter is to give display image on the screen.. If these were busted then what you will be seeing is black on your screen. You can also replace this.
Please rate this solution if this help you. thanks..
May 27, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Unknown mods sva vr17s
A little more information about your requirements on assistance may help.
Oct 10, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
SVA 17" flat monitor screen color is pink.
It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
Apr 10, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
ViewSonic VE710b 17 inch yellowed photograph look
Check and make sure that there is no speaker, power supply or UPS around your monitor.
Mar 16, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Sva 15" flat screen monitor
You have a bad power supply capacitor or two. Very common. Not worth fixing, these are free on craigslist *replacement monitors like this
Oct 27, 2007 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
SVA-USA VR 17 17" Flat Panel LCD Monitor Logo
121 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
