Question about EliteGroup (ECS 915PL-A2) Motherboard
No power I have installed a 915PL-A2 motherboard and built onto it a Radeon HD2600 pro Graphcs card. When I switch it on it only it starts for about a second and then stops. Any Ideas please?
    Sergeant:
  • 320 Answers
Make sure the cpu fan is properly placed on the processor or not !!! It might cause the problem..
Thank you......
Posted on Oct 09, 2008
Describe your (ECS 915PL-A2) Motherboard Problem do not detect hard disk and dvd rider in the bios
1. Check if both drive data and power cables are correctly and tight fitted.
2. If both are fitted on PATA (IDE) on the same port/cable:
The harddisk should be the MASTER and DVD the SLAVE device.
3. Recheck.
4. If not OK, Power OFF the computer (also from the wall outlet).
5. Place the mainboard jumper for CMOS RESET to the other position for a few seconds and place it back.
6. Turn the computer Power ON and check.
Aug 25, 2011 | EliteGroup (ECS 915PL-A2) Motherboard
Cannot find the SATA hard drives for my ecs 915PL-A2 mother board. All connections have been checked
Did it just stop? Or is the a new system?
Did you check your BIOS settings?
ECS is not known for excellent quality - if you have a bad board hopefully it is still under warranty.
Mar 04, 2010 | EliteGroup (ECS 915PL-A2) Motherboard
Shutdown at Windows Log-in or Desktop
Hi kpspero, I gather you can get into you're bios? Once there go to hardware monitor (page 26 in you're manual, which should allow you to watch the motherboard temp & CPU temp. You're CPU may be overheating. (Keep the case closed when checking this). Normal operation. Did you add thermal grease between the CPU & heatsink? Go to page 4 & 5 of you're manual. Check that you have connected number 21, Auxiliary 4-pin power connector.
Two more thoughts. If everything is connected correctly & you're system is not over heating, try updating the bios. Click on this link which will take you to ECS's web site for you're board.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=533&DetailName=Bios&MenuID=44&LanID=0
After flashing the bios, re-check you're bios settings. There are many updates for the 915PL-A2 MB & for windows. Did you hear any beeps from the PC during boot up? Did you connect the motherboard speaker? If you do not have a motherboard speaker you can get one from this site:
http://store.cwc-group.com/casp.html Lastly, since you can get to you're desktop, from time to time. Is this a fresh install of windows XP? Have you installed windows more than once? If you said yes to either. Download the hard drives manufactures bootable floppy disk setup software/tools/utilities & use that floppy to format the hard drive & setup the drive. Do not use windows to perform the format. Install ECS's CD software/drivers after windows has been installed.
If you're system continues to has this shut down problem, post back & I'll go from there.
Good Luck!
Mike
Jun 08, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
No Video!
Have you tried a CMOS reset (sorry if this seems obvious, but I'm just making sure)?
Jan 07, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
ECS 915PL-A2 motherboard RAM upgrade
try to reset the cmos first so that the bios would refresh
Dec 23, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
Cpu fan starts but no other indications
If there a built-in videocard on your motherboard you must disabled it from the CMOS setup before you can use to the separate video card.
Please give me any update
Nov 24, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
No post, no video
get some cheap PCI card plug it in. get to the bios make sure integrated video is selected. Speaker connector is two pins in various motherboard the pins should be located close to the reset and power pins.
Oct 26, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
No post beep, no video
had a similar problem with a box i built. Your power supply has two connectors. One long one and a 4 pin connector. Make sure that four pin connector is connected.
Oct 25, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
Ecs 915pl-a2 v3.1b
Check this out http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=533&DetailName=Specification&MenuID=44&LanID=0
Oct 19, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
EliteGroup (ECS 915PL-A2) Motherboard Logo
62 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
