Question about Maytag Refrigerators
How to change evap/heat exchange assembly on my refrigerator
  • 1,543 Answers
Please don't rate this, as anything other that FixYa drops my rating, but I feel you'd like an answer, even if you don't like what it is.
This is DEFINATELY NOT a do it yourself job !
If you have to ask, I'd say you are not certified to handle refrigerants, don't have an evacuation pump, or the proper charging equipment. Then of course there's the brazzing with silver solder too.
DO NOT ATTEMPT THIS REPAIR YOURSELF.
Posted on Oct 09, 2008
The ice maker is not working and the water dispenser is not working right. I've changed the filter,checked the water supply and reset ice maker and waited 24 hours. What's next?
First make sure you have water going to refrigerator Samsung water filter heads go bad and won't let water thru or it could be the fill valve it's right near the filter
May 30, 2016 | Samsung RF4287HARS French Door...
GE ARTIC PROFILE REFRIGERATOR....INTERMITTENT HEATING
Sarct, the question is, was the freezer side ok, if it was, I would suspect the damper not opening. If the freezer side was warm too, then I would suspect the evaporator thermistor not sending the signal to the board to terminate the defrost. Have the tech first check the continuity at connector J3. He should have 400ohms at J3-1 to J3-2 and the same at J3-3 to j3-4. If he doesn't get those readings have him check at the damper motor itself. If he doesn't have it there, replace the damper motor. If the damper motor passes all the checks then it's on to the evaporator thermistor. Have him check the resistance. At 5 degrees it should ohm at approx 36K ohms. The evap thermostat is redundant to the defrost operation. It's there as a back up in the event the evap thermistor fails to terminate the defrost. It's normally closed and will open at 140 degrees.
Dec 20, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
To continue from my last Question, to do with HVAC Evaporator/Condenser Cycles, how often should the System go into Heat Standby, Heat Defrost, and Heat Modes? What are Heat Standby and Heat Defrost?
In this type of system (heat pump), the evap and condenser swap functions by means of a reversing valve, according to the mode selected. Evaps throw off cool air, condensers, warm air. In heat mode, the condenser is the indoor coil and it throws off heat from the outside air. Vice versa for the cooling mode. Heat Standby would be whenever the temperature thermistor has reached set point by the user and shuts down the system. Heat defrost is the cycle that reverses refrigerant flow and defrosts the outdoor coil by sending warm refrigerant liquid to that coil. In heat mode, the outdoor coil builds frost and ice on its surface.
Feb 05, 2015 | Refrigerators
Samsung RS2630SH REFRIGERATOR SIDE HEATER
If this is the duel evap, Bad design, the heater and evap all one part . But you can remove the heater from the assembly very carefully
Oct 17, 2012 | Samsung RS2630SH Side by Side Refrigerator
It is leaking out of the bottom - heat exchanger?
need new heat exchange either chemical damage or overheating due to incorrect gas pressure then tubes start bending and pulling away from walls not covered by warranty
Feb 12, 2011 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
Refrigerator not cooling properly
evap. coil could possible be frosting up due to a defrost problem, this would keep the evap. fan from blowing air into ref. section. it also could be a bad evap. fan motor or it could be that the ref. inside light bulb could be staying on due to a bad light switch ,you would be surprisedhow much heat a 40 watt bulb produces
May 07, 2009 | Kenmore 64802 Top Freezer Refrigerator
Fridge side warm but the freezer side cold
it sound like your defrost heater or defrost sensor in the freezer is not working,do you know if it is going into defrost every 8 hours?if you have an ohms meter you can check there parts no problem ,let me know if you want to tackle this and i will help-mike
Nov 02, 2008 | Maytag MZD2752G Side by Side Refrigerator
Ice at bottom of freezer of MAytag MSD2756DEW
CALM DOWN . YOU ARE SUPPOSED TO FEEL HARM AIR AT THE BOTTOM OF THE RF AT THE KICK PLATE IT CALLED HEAT EXCHANGE WHICH IS A GOOD THING CAUSE WITHOUT MEANS YOUR MACHINES SEALED SYS. IS DEAD BUT THAT NOT THE CASE SO IF YOU HAVE ICE AT THE BOTTOM OF THE FREEZER THAT MEAN YOU HAVE A CLOGGED EVAP. DRAIN. TAKE TE BACK PANEL OFF THE FREEZER AND AT THE BOTTOM OF THE EVAP. COILS YOU WILL SEE THE DRAIN WHICH WILL BE FULL OF ICE , USE BOILING HOT WATER TO MELT THE ICE AND CONTINUE TO DO SO UNTIL THE DRAIN FLOW SMOOTHLY DOWN INTO THE DRAIN PAN. YOU HEATING ELEMENT IS FINE BUT YOU MAY WANT TO CLEAN YOUR CONDENSER COILS
May 17, 2008 | Maytag MSD2656G Side by Side Refrigerator
Frigerator not cooling not cooling at all
make and model # was there frost on the evap.?
Sep 12, 2007 | Daewoo FR-147RV
Refrigerators Logo
60 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
