Question about HP Color LaserJet 2600n Printer
Printing using color laserjet 2605
The colors that a printed are different colors from what I see on my PC. The toners are all new. Please help
    Problem Solver:
  • 13 Answers
Try uploading the firmware from hp.com, unzip it and post it to your desktop. You can use a "print to file" program to download it to your printer. Procon.com has a free trial Fil2prn program that will work for 30 days. This may solve your color match issues. Also when opening the driver window, check your graphic settings, you may make the default ICM pictures or graphic,and set the ICM method as "handled by printer". You will find these options when opening your driver under preferences/advanced. Hope this helps.
Posted on Oct 17, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
1-it may be that there is a color that is not printing well run a test page and it will show you which one is off
2-if they are generic toners sometimes the colors are not as "deep" as the Originals, you may consider returning them as defective and trying a different batch of gen.
Posted on Oct 10, 2008
2 Suggested Answers
  • 24 Answers
SOURCE: printing incorrect HP color laserjet 2605
Possible causes
Bad Print Drive
Remanufactured Toner Cartridges
Print a Demo page from the Printer Control Panel. You do this by pressing
Menu
Computer Information
and then select the Demo Page and press the Green Key to select that choice
Posted on Nov 06, 2008
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Oct 09, 2009 | HP LaserJet 2605DTN Color Printer
HP LaserJet 2605. The printer indicates that it is low on toner by a Toner Beaker Pictogram, even though have put in 2 different OEM Black Toner Cartridges
I've seen this before.
Do the test print, from the printer's built in menu system, that shows the cartridge serial number.
You'll find that the serial numbers of the cartridges that produce this 'problem' are a different length than ones that don't.
There is ar firmware update ecommended for HP Color LaserJet 2605 series printers that have a version prior to 20071108. This utility updates the printer firmware version to 20071108. Your printer's current firmware version can be found on the Self Test/Configuration Page which can be printed from the printer's Reports menu.
Here's the link to it
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=uk&prodTypeId=18972&prodSeriesId=1140727&prodNameId=1140730&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ly-40741-3
Oct 02, 2009 | HP Color LaserJet 2600n Printer
HP LaserJet 1500... prints color yellow ONLY
It's possible that the toner in the cartridge is not evenly distributed. You can redistribute toner if you gently shake the cartridge from side to side, then reinstall it to see if this affects performance. Please also see this article.
You might wish to use the guided troubleshooting option available from HP support here. Or have a look at the troubleshooting section in the user manual here. Then clean the engine & calibrate the printer, as described pg. 88.
If that's no help, please see this forum post and the linked attachments within.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 01, 2009 | HP LaserJet 1500L Color Printer
Printing incorrect HP color laserjet 2605
Possible causes
Bad Print Drive
Menu
Oct 09, 2008 | HP Color LaserJet 2600n Printer
Can't color balance 2605
well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
Feb 07, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
210 people viewed this question
Ben Johnson
