Question about Jenn-Air JCB2285HES Side by Side Refrigerator
Loud buzz sound...
We are getting a loud buzz sound every 15 minutes or so... both sides are maintaining tempatures so I am confused... any idea what could be causing this buzz sound?
Thank you in advance,
  • Anonymous Mar 16, 2009
    Lod buzz every 15 minutes or so... had compressor replaced last week and this is when the problem started.
HVACRH20
  • 237 Answers
SOURCE: Jennair JCD2389G side by side
Can you tell where in the unit the buzzing is coming from (top bottom inside outside, etc)? Need a little more information to help.
Posted on Dec 04, 2006
SOURCE: kenmore elite dishwasher making loud buzzing sound when washing
I had the same problem with by Kemore Ultrawash after two years. The motor bearing went bad because the seal went out and dish water got to the bearing. If you are handy, this motor comes out after taking the dishwasher out. I was surprised how easily the motor came apart from the dishwasher, a good design. The motor has three screws that holds it together, I took them out and took the motor apart.
I took the old beaing off the shaft with a grinder, careful not to groove the motor shaft. I did, but just put some high temp silicone caulk in the groove before I put the new bearing on the shaft. I bought a new bearing on the internet, it is a 22mm x 8mm x 7mm. I bought one that went in a small engine, a quality one. I placed it on the shaft, put the motor back together and put the dishwasher back together. It has run quiet and great for many weeks now. I expect the dishwasher may last many years now, because the bearing I took out was a cheap aftermarket one, and the new one is vastly superior in quality.
Good luck and fire away with any questions. I love this dishwasher and am glad I could fix it for 19$ and some of my time.
Posted on Nov 08, 2008
  • 534 Answers
SOURCE: My microwave makes a loud buzzing sound
Magnitron is going out. Suggest discarding microwave it will possibly go completely out in the near future. Good luck hope this helped
Dave
Posted on Nov 02, 2009
  • 572 Answers
SOURCE: maytag dishwasher starts to fill with water and as
you need to get inside to the chopper and see if its stripped. usually parts strip there
Posted on Feb 11, 2010
ginko
  • 19396 Answers
SOURCE: ONCE THE DISHWASHING CYCLE BEGINS, A LOUD,
Hi.
Problem is likely a jammed impeller pump. The repair is done accessing the hose connected to the impeller pump and removing blockage. In some case the pump is broken and it is necessary to replace the pump.
Before testing anything else ensure that power is off. also rotate manually the spray arm and ensure that this are free to rotate and are not hitting baskets and other parts.
To find parts and diagrams try entering the full model number (as from service tag) in the websites listed at the link below:
Enter the model number ...
Regards.
Ginko.
Posted on Dec 30, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My TV takes about 15 minutes to start playing.
It sounds like you have a problem with your signal board. The signal board will need to be replaced.
you can get parts for this tv at www.interliquidparts.com
Feb 22, 2012 | Televison & Video
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Loud buzzing noise
Mine is loud also when playing games. When playing DVD's it is not. I think it is a factory defect on some of the systems. I would not attempt to pull apart the DVD drive and try and fix it. It is working and on an XBOX 360 you should feel lucky that it is.
Aug 18, 2009 | Microsoft Xbox 360 Console
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
JVC plasma has a loud buzzing noise
sounds like power supply is going bad.
Feb 28, 2009 | Televison & Video
Loud Buzzing Sound
Sounds like the cooling fan blades are hitting something (possible worn bearings).
Apr 21, 2008 | RCA P52926 52" Rear Projection Television
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Jenn-Air JCB2285HES Side by Side Refrigerator Logo
60 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
