Question about Asko Dishwashers
Asko dw95.4 dishwasher flashing f2 when switched on
    Sergeant:
  • 351 Answers
Remove the dishwasher from under the bench and tip it back to let the water run out from underneath,remove the rear panel at the bottom and run test for leaks or blockages.
Posted on Oct 09, 2008
  • 641 Answers
SOURCE: F2 Error Message on my Asko D1776
F2 error message means that you have a high water level problem that could be caused: - A plugged or bed water pump - A defective water inlet valve (stay open) Good luck !
Posted on Jul 27, 2007
SOURCE: Asko Dishwasher F2 Error Flashing
This was very helpful! Only 2 weeks ago I replace the circulation pump on my Asko 1855. Today, when I turned the power on, the F2 error message appeared. I removed the face plates and discovered there was a lot of water in the drip pan. I found the cause to be a small leakage on one of the hose connections. After removing all the water, the water level switch worked properly.
Posted on Aug 17, 2008
SOURCE: ASKO Dishwasher F2 light flashing
Hold the Rinse button for 5 seconds to reset.
Posted on May 19, 2009
SOURCE: How do I reset an F2 warning on my dishwasher
Hold in the start stop button till it resets
Posted on Dec 11, 2009
joe_lishman
  • 192 Answers
SOURCE: Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Posted on Mar 26, 2010
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
Asko d1876
I'm not sure about that model, but on an older one, just under the drain area there is a piece os styrofoam attached to a switch. I guess if it rises it activates the circuit. Problem is if it drys it sticks, so push it down with your hand gently. This involves taking off that bottom kickplate area, but that's the only way in there.
Jan 25, 2009 | Asko D1876 Dishwasher
Jan 19, 2009 | Asko D1776 Built-in Dishwasher
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Apr 22, 2007 | Asko D1976 Built-in Dishwasher
Dishwashers Logo
558 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
