Question about Soundstream Car Audio & Video
Pca2.520 protection led on red,disconnected
Soundstream car amplifier pca2.520 protection led on red,disconnected power,remote,earth cables speakers cables aswell.hooked power,remote and earth but did not hook up speakers yet.amp turns on but is still in protection mode.how do i get the green light to come back on
5 Suggested Answers
SOURCE: speakers cut off when bass goes up...
i had this same problem, i have a 1993 s10 blazer, i would put it up past 18 and all bass would cut out, The only problem was there wasnt enough power gettin to the amp. The ground wire came lose and wasnt getting the power to the amp
Posted on Apr 05, 2007
xtpfly
SOURCE: protection light on
go to power acoustiks website at: poweracoustik.com then tech support look at how to insatll an amp
Posted on Jun 29, 2007
  • 4 Answers
SOURCE: Fusion Amp Starts In protected Mode
check remote wire coming from back of radio
Posted on Jan 08, 2008
  • 631 Answers
SOURCE: lightning audio B300.4 amp protect light
The most likely reason for it to go into protect is shorted output transistors.
Posted on Jan 16, 2008
  • 112 Answers
SOURCE: car amplifier install issue
check the remote cable from your head unit to the amp first.
Posted on Apr 20, 2008
Tc 8001 red light
on some amps there is a duel light. red and green usually. red means it is in protect mode or you didn't hook up your remote wire. if in protect mode, it could mean a number of things. did you hook it up with speakers and everything?
Mar 01, 2012 | MTX Thunder® TC8001 Car Amp
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    The saftey red light keeps coming on
    It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
    Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
    I have a brand new soundstream xxx 6500d amplifier and when i installed it for the first time protect mode light come on even without rca jacks and speaker wires hooked up. any1 can help?
    You need to plug in the RCA and speakers you could blow the amp. The amp is sensing no Input and No output. I would unplug the amp wait around 30 seconds then install the rca and speakers THEN install amp to battery + cable. You should be ok.
    Jan 24, 2010 | Soundstream Xxx-6500d Power Amplifier Xxx...
    What does the orange light protection mean
    Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
    .A thumbs up would be greatly appreciated if this answer is helpful to you
    Dec 06, 2009 | Kicker ZR1000 Car Audio Amplifier
    Amplifier has no sound
    Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping.
    A thumbs up would be greatly appreciated if this answer is helpful to you. amplifier-no-sound-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
    Jan 10, 2009 | Rockford Fosgate Punch P325.1 Subwoofer...
    Protection light comes on when amplifier is hooked up
    If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
    With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
    If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
    Sep 15, 2008 | Kicker KX600.1 Car Audio Amplifier
    Protection Mode? amp wont start
    With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
    If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
    Nov 29, 2007 | Power Acoustik LT960 Car Audio Amplifier
    Amp has Red LED light on.
    Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
    Nov 05, 2007 | Soundstorm F2600 Car Audio Amplifier
    Car Audio & Video Logo
    21 people viewed this question
    Top Soundstream Car Audio & Video Experts
    Matthew Spark
    Matthew Spark
    Electro Med Services...
    Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
