Question about Samsung SGH-E900 Cellular Phone
Slid tone not opn phone can i install one - Samsung SGH-E900 Cellular Phone
    Brigadier General:
  • 7,752 Answers
Yes you can...but you cna press *2767*3855#
Posted on Oct 25, 2008
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
My ringtone and vibrate alert is not working when i have a incoming call
Open menu and select tones see if the ringer settings are in place, if not set the tone and volume and set ******** to on.
If this does not bring in the ringing,then opne menu, setttings, restore to factory settings-- type 12345.
the set will go to factory settings.
If not remove batter and reinsert after about 10 minutes.If there is no result then the phone hardware can be faulty.
Sep 02, 2010 | Nokia Lands Phones
Hello !! can i change the message tone of my sams...
go 2 settings...opn phone profiles >> click tis mark.... d top rit side ull find a tangle shoving dwn sign...click it...dan click on nw msgs....ull find msg alert tone der...opn it...at d rit bottom ull find "sounds"...opn it..choose t tone n save it....
May 21, 2010 | Cell Phones
GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
May 28, 2009 | Uniden Cordless Phone
My 2001 chevrolet prizm automatic light control not working
is the tone like a tone you hear but diffrent pitch then your blickers?
Nov 20, 2008 | 2001 Chevrolet Prizm
Downloading Ringtones
try saving the tone to your phone rather than your sim card?
Aug 08, 2008 | Pantech VZW PN 215 Cellular Phone
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Motorola C139 Ringtone problem
After you made the ring tone, go to Menu, Ring Styles.
Go to Loud Ring Detail, the go to Messaeg Tone. At the end of the factory installed tones, you will se the one(s) you made. Select it!
Apr 27, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Samsung SGH-E900 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
