Question about Microsoft Computers & Internet
Documax datasouth a3300 series printer drivers for windows xp
I want datasouth a3300 series drivers for windows xp
Driver for Acer 4738 series for XP
Acer stop supporting the Aspire 4738 Series for Windows XP. They currently only support and host the drivers for Windows 7.
However, I was able to find a copy of the older Windows XP drivers for your laptop, which are located here: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 23, 2011 | Computers & Internet
I want hp psc 1315 all-in-one printer scanner copier Software & Driver
Here are thedrivers . When you click on the links, give it a minute and they will'pop-up' on your screen. When you click 'Save' the driver package willbegin to download. OS Type Version Date Added File Size File Type Download Link (About) Windows XP Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows XP Printer Driver Download Windows 2000 Driver 4.2.0 - Basic 2008-05-17 48.54 MB exe HP PSC 1315 Windows 2000 Printer Driver Download Windows XP 64-bit Driver 1.0 - Beta 2008-05-10 58.43 MB exe HP PSC 1315 Windows XP 64-bit Printer Driver Download Windows Vista 64-bit Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista 64-bit Printer Driver Download Windows Vista Driver 080.001.237.000 2008-05-13 163.07 MB exe HP PSC 1315 Windows Vista Printer Driver Download Windows 7 Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 Printer Driver Download Windows 7 64-bit Driver 13.1.0 2009-12-04 362.68 MB exe HP PSC 1315 Windows 7 64-bit Printer Driver Download ALTERNATIVEDOWNLOAD LOCATION.
Note: These are LARGE files and may take some time to download.
Save the driver file somewhere on your computer where you will be easily ableto find it, such as your desktop.
After downloading, go to the location where you saved the file and double clickon the file. Then simply follow the on-screen instructions for installing thedriver.
HPPSC 1315 Windows 7 Printer Driver Download
HPPSC 1315 Windows 7 64-bit Printer Driver Download
THE HP SOFTWARE IS AVAILABLE THROUGH YOUR OPERATING SYSTEM. ON WINDOWS CLICKSTART AND THEN SELECT THE WINDOWS FAX AND SCAN ICON.
Software: Download optionsand information Description: clip_image002.png This software installs a copy of the help files onto your computer. Install this software if you did not install from the CD or if you did not install the full featured version of the software. Do not install this software if the help files for the HP PSC 1315 are already installed on your computer.
To see if the help files are already installed on your computer, check the following destination:
Windows XP: On the Windows taskbar, click Start, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help.
Windows Vista: On the Windows taskbar, click the Windows icon, click All Programs, point to HP, click PSC All-In-One 1310 series, and then click Help. Details andspecifications File name: clip_image002.png MaggiMinus_Installer_24Nov08.exe [1/1, 24.91M] System requirements: clip_image002.png No additional prerequisites Released: clip_image002.png 2008-12-04 Version: clip_image002.png 1.1 Compatibility: clip_image002.png Microsoft Windows Vista, Microsoft Windows Vista (64-bit), Microsoft Windows XP 64-Bit Edition, Microsoft Windows XP Fix/Enhancement: clip_image002.png Updated the file to make the help files available from the Windows Start menu after installation is complete.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-66177-3&lc=en&dlc=en&cc=us&os=228&product=374568&sw_lang=&key=null&site=null
Apr 13, 2011 | Computers & Internet
Am looking for driver for an hp officejet 4100 series all-in-one, it just have 98, ME, 2000, XP os, in need a driver compatible to windows 7
click start, then devices and printers
Click add a printer
choose the port it will hook into...if the USB port isn't listed, that's ok, just choose LPT1 for now
now click the WINDOWS UPDATE button...very important! You must have internet to do this!
it will download a whole whack (yes, that's the technical term for the amount) of previously unlisted drivers.
Once the update is done, you can choose HP as the manufacturer and Officejet 4100 series as the printer.
It's just follow the prompts after that, and then plug in the printer.
If it doesn't automatically install the printer at this point, It should find it as new hardware, but this time you can choose HP and Officejet 4100 series for the printer because the driver now exists!
Happy printing!
If you run into any snags, post a reply here and I'll try to help you through it.
Feb 24, 2011 | Computers & Internet
Trying to fax from windows XP Professional. Have
Have you downloaded and installed the device-driver software from HP's web-site (http://support.hp.com) for this specific all-in-one device? It may include software to cause "printing" from Windows to be routed to the FAX-interface on the all-in-one.
Oct 29, 2009 | Microsoft Windows XP Professional
About printer
Sounds very odd the printer would not be supported by windows XP as it is the main OS used today, go to the samsung website and search the driver download section for a XP driver, if the driver on the cd has a known issue with SP3 then they will have released a new version.
Jul 02, 2009 | Microsoft Windows XP Professional
Problem installing Windows XP with Asus P5RD1-VM series mothboard
Hi!
You need to copy the SATA drivers from the motherboard CD into a floppy diskette.
When you are booting with the windows xp installation CD you can see a message that says:
Press F6 for raid drivers
Press that key so windows installation CD look for the SATA drivers.
Jan 20, 2009 | Microsoft Windows XP Professional With...
Connect an Hp laserjet printer through a card : pcmcia/2 parallel ports
hi check out the following link...
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=Hp+laserjet+printer+1100&submit.x=0&submit.y=0
I was not sure if yours is Hp laserjet printer 1100 or Hp laserjet printer 1100se or Hp laserjet printer 1100xi... or the all in one series....
Just check out the model... from the site the link takes you to choose the appropriate printer model... then select the Operating System you use and then download the driver...
I just wanted to be doubly sure that you gave the right printer model... Just in case...
Am sure this link would have taken you to the driver you were looking for...
If the problem still persists after downloading and installing the appropriate driver just leave a comment i will check it out...
FixYa!!!
Oct 18, 2008 | Microsoft Windows XP Professional
Couldn't install lexmark 8300 printer software on my window vista driver computer
Follow this link to the official Lexmark website and download the driver.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
If you can't follow that link, go to www.lexmark.com. On the top menu, there is a link called "Drivers and Downloads". Click it and select your series, then your OS system, and there you go.
The drivers for Vista are finally updated.
I had the same problem for about a year... now it works fine.
-Ciao!
-Wizkid
Jan 11, 2008 | Microsoft Windows Vista Ultimate Edition
Change of os
Review following link the question at the top of the page before entering series (F5) and product (F5R) and pressing go
XP Conversion info
This conversion is not a trivial process and may have repercussions on device operation -- I have not read everything
For the following link this page Product (Notebook), series (F5) and product (F5R) and pressing search
Then set OS to WinXP and click all tab to see possible drivers and documentation to consider.
XP Drivers
I hope this helps -- good luck
Dec 16, 2007 | Computers & Internet
Computers & Internet Logo
1,001 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
