Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
Sony DCR-HC44 cannot load a tape
I have a DCR-HC44 that cannot load a tape. the cassette compartment is in thread end position. when the cassete compartment door is put in tape eject position , the cassette compartment will open. when it is closed it remains in the unthread end position and does not load the cassette. Ive tried driving the loading motor manually to the thread end position. In this case when the cassette compartment door is opened , it unthreeds normally, but when the cassette compartment is closed it will not thread.
Please help me with a solution to this.
  • Anonymous Jan 21, 2009
    Our problem is, we have a hard time closing the tape recorder into its normal position thus we cannot used it until now.
  • 14 Answers
SOURCE: Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
Posted on Jan 08, 2008
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
SOURCE: Canon zr300 ejects tapes
I just tried the "Fonzie" fix in my ZR300 and my camera now works - cassette compartment closes all the way now with the tape inserted. It just took one "hit" to fix the prolem. I was surprised. But ericemartin's solution is worth a try.
Posted on May 28, 2008
bluelikealex
  • 52 Answers
SOURCE: TAPE COMPARTMENT KEEPS POPPING OPEN
I Had The Same Issue And Fixed It :o) I Have A Sony Handycam CCD F-730A 8mm. I put the tape in and close it but it would not load the tape down. It just pop back out. If I took the tape out, it works perfectly and would loaded the tape doc down and close.
1st: I unscrewed and removed the door to the tape. Where the tape can be seen. 2 screws hold it down. Without the tape inside. I Saw a Clear Small Plastic in the inside of the camera where the tape sits on each side. On Both Sides, Left and Right are clear plastic like sensors. They look Like Glass and are small.
2nd: I Cleaned them both with a Q-tip and rubbing alcohol. It Worked. The tape loaded and worked nicely.
It was strange. If i touched one of the small glass like sensors. the mechanism the loede the tape would not work. When The Glass sensor was blocked by the tape or just by my finger in front of it, it would not load. Very strange.
Bluelikealex :o)
Posted on Dec 02, 2009
  • 61 Answers
SOURCE: canon camrecorder will not load cassettes take
is tape in right way??
Posted on May 19, 2010
Sony DCR-HC42 cassette won't load completely. Door closes all the way without a cassette, but only closes hal way ith a cassete.
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Feb 27, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
I have a sony handy cam with cassset recorder type. it is five year old model. cassete does not insert in the its compartment .only going inside the comprtment and again come back and come out from...
Possible that:
1. The drum- the cylinder head is faulty , it is not spinning. It could be failure of the IC or the hall IC. need to replace.
2. Fault in the dew switch or is faulty.
3. Fault in the loading tray mechanism as it fails to land.
4. fault with the capstan motor or the forward loading mechanism.
Jan 14, 2011 | Sony Handycam DCR-TRV17 Mini DV Digital...
Sony model# SLV-D500P: The casset loading motor does not stop
Hi, thats is a mode switch and mechanism
alignement problem;;; if you turn manually
loading motor belt vcr unpluged until the cassette
housing is in loading position dont put a tape in,,
plug it again the cassette housing should go back in eject position thats is a good way to verify the mechanism. then try first to replace the loading belt
the idler wheel and the capstan belt then try to insert
a tape in if it doesnt work you wil have to clean the mode switch and verify the mechanism alignement
if you not sure or not familiar about this process
you can hask a friend who you know he is familiar whit this or see a repair shop its a 30 minute job
hope that will help you
have a nice day
Apr 09, 2010 | Sanyo VWM-700 VCR
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Where can I download the owner manual for a Sony DCR-HC44???
Please download User Manual of DCR-HC44E from Sony Support.
User manual has details about uploading recorded files in PC.
Thank you.
Dec 19, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony PVW-2800 Beta SP Deck / Tape wont load - Error 20
Error 20 is "Cassette compartment motor lock" this is meaning the cassette loading mech is not accepting the tape It could be miss-aligned in it's position or one of the sensors is defective or the motor is bad
May 08, 2008 | Sony PVW-2800 VCR
DCR-HC42
  1. I'm having the exact same problem. It wont accept the cassette...only half way then errors. It will close fully without a cassette as well. hmmmmm
Comment by Guest, posted on Apr 02, 2008 Load cassette, turn it on, then message says re-load cassette. Door to cassette compartment only works half way. After fiddling with power, can get the cassette door to open and close all the way, but not with cassette. Tried several brands of cassettes, no joy.
Mar 09, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
The cassette holder isn't closing......and the tape is not loading
not geting in holder tht mean u must open ur casset holder and put in polethin bag for a hour and it will accept tape
Aug 14, 2006 | Sony Handycam DCR-HC42E Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
127 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
