Laptop to TV Hook Up
I own a IBM ThinkPad 380Z, ThinkPad T20 and a ThinkPad T40 and I'm wanting to hook up my 380Z to my Tv. I've turned my ThinkPad 380Z into a Desktop working way since it is bigger than my other 2 laptops and have a Wireless Mouse + Keyboard for it. I orderd a VGA/AV Cable for it and pluged it in and I get no display on the Tv. The Cable's one end is VGA while the other is a S Video and one yellow AV. My Tv don't have any AV nor S Video Ports on it. It has the wholes on the back of the Tv for a set of 4 row AV plug in's but they must of not added them to it. So the VCR is the only way I can play my games and DVD player on the Tv. My Tv is a SANYO 32", a Basic Tv not a LCD. and so I took it out in the living room Tv witch is a newier SANYO Flat Screen Tv, "Not LCD" and I pluged in my 380Z and put it on INPUT 1 and I get the display of the laptop but I just get a blurr small line that streches to top and bottom in the middle of the tv witch can see alittle of what is displayed. So I pluged in the T20 and same resalt and then T40, same too. So I pluged it into the only LCD tv I have witch is my PSone and it comes out the same to. So I don't think I need a LCD tv for it to work. and I've seen it done on these tvs before.
  • ayazbaigpk Dec 28, 2008
    I have Fujitsu Siemens V3515 Amilopro laptop and Samsung TV. I want to hookup my laptop to TV. Can anyone explain that is it possible and if yes then how?
  • 135 Answers
Reduce the video resolution on your "input".
Posted on Oct 11, 2008
Need info about series
The type of drive is IDE and 2.5- Inch for all those models.
T20, T21, T22, T23 --- 2647 all use the same IDE type of drive.
These you can buy for example in ebay. Search for laptop hdd ide 2.5inch or similar.
Jul 01, 2012 | IBM ThinkPad T40 2373 Notebook
I have an IBM T40 Laptop and I wanted to display my video to the television screen via the SV output. When I hook everything up, all I see on the television is the Windows Desktop background, no icons etc....
You set it to Multiple Monitors (if you move the mouse, you will probably be able to see it on the TV once it "goes out" of the laptop desktop). You need to change output mode to external S-Video.
First of all try hitting Fn + F7 key to switch to Ext-S-Video. If it works, that's it, of course. If it doesn't, TV output is not enabled.
Right-click on the desktop to bring up the Properties, go to Settings. You'll see two monitor images there, 1 and 2.
Click Advanced, then go to Displays. You'll get CRT, TV and LCD. Turn on the TV button and tune your settings.
At this point, the hotkey Fn + F7 is enabled to cycle between LCD and TV.
If it still doesn't work and you see the blank desktop, go again in Display Properties, choose LCD as Primary Display, select Secondary, and verify that "Extend desktop on this display" is NOT checked.
Nov 03, 2009 | IBM ThinkPad T40 2373 Notebook
Thinkpad t20 s video not working
This may sound silly but it is often overlooked by many people......Have you changed your T.V channel to AV? There is usualy av1 and av2 options. Try these and let me know if you have any success or not.
Regards,
Graemevm
Apr 22, 2009 | IBM ThinkPad T20 2647 Notebook
IBM LAPTOP T40- NO POWER
I had a T20 with the same problem.  Com to find out it was a bad power supply cord.  Replace the whole thing.  Get one off ebay really cheap.  That should solve your problem.
Mar 02, 2009 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad R40 No PowerUp
If the the ram is the problem of your system, there should be a power on light on the system. indicating that some of the component of the system is not working correctly. But since you mentioned there is no light, it is the possibility that the problem is the motherboard itself.
Feb 26, 2009 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad T20
Wow, a lot of information but I'm unclear as to what you are trying to do.
Are you connecting the T20 directly to the T40 using a cat5 cable and then trying to access the internet on the T20 via the modem?
Connecting the two computer together using a normal cat5 will not work, you need to use a crossover cable otherwise you are connecting the send to the send and the receive to the receive.
You can also use a hub, a switch or a router if you have any of those on hand.
As for the modem, I suggest you unplug the telephone line from the modem and plug it into a phone and see if you can hear a dial tone. If you cannot hear a tone either the extension is bad (replace) or you outlet is defective. If you can hear a tone, the modem card may be defective.
Oct 08, 2008 | IBM Thinkpad T20 Notebook
IBM ThinkPad 380Z AV Hook up To Tv
From what I have been reading, the video card in the computer itself MUST support TV out. You can't just use a TV like a computer monitor...it won't work. Check the ads on eBay for those adapter cables and they will say: Check to make sure your video card supports TV out. Go back to eBay and search in the same general area for a computer video to TV adapter or converter box. DO NOT get it confused with the converter box for HDTV. They are about $25-$35 and you will still need the cable adapter you already have, plus another set of just the AV cables. Good luck. Please rate this if it was helpful.
Sep 26, 2008 | IBM ThinkPad 380ED
IBM ThinkPad T40 Hard Drive Problem
HI IM LOOKING FOR THE DRIVRS FOR MY LABTOP T40 I NEED ALL OF THEM I LOOKED IN TO IBM SUPPORT.COM BUT I CANT FIND IT SO IF ANYONE KNOW WHERER I MAY FIND IT HELP ME OUT THANK YOU
Sep 22, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad 380Z
Any time Patrick. Need anything else just holler.
Aug 01, 2008 | IBM ThinkPad 380ED
Computers & Internet Logo
1,381 people viewed this question
David Payne
David Payne
