Question about Microsoft Xbox 360 Console
My xbox can not read a game disc
When i turn it on it says its "reading" but after a minute it says"disc can not be read"
    Problem Solver:
  • 6 Answers
Try using a disk cleaner for the drive or if the disk is damaged you can get it repaired from a game shop for cheap
Posted on Oct 09, 2008
How to remove the hurdle that I am getting in Xbox 360 that it is unable to read disc of Xbox Gaming Console?
If you newbie user of Xbox and you need some technical help you can switch this toll-free Xbox contact number 1800-875-393 for Australia and talk to the expert technicians who are highly skilled in this field. They can assist you some easy way top resolve the issues whatever you are facing such as you are not able to read hard disc of Xbox in a couple of minutes that you was expecting. The benefit of the helpline is that it is available for 24*7 to resolve every kind issues related to Xbox.
Feb 13, 2017 | Video Game Consoles & Games
I can't play any games on mmy360
Are you referring to your xbox won't read game disc, or it won't load any downloaded game on your xbox and games on disc?
If it is your disc drive, this may be a major issue to the point where your disc drive no longer works, and you will have to take it in somewhere to get it replaced, or it could just be that your disc drive is dirty and you simple just need to clean the disc tray off.
If it isn't loading any games at all, you may just have a stalled xbox and need to turn it off and give it a minute or two. If that doesn't happen to be the case, your storage on the xbox could be full, causing your xbox to run slower and not cooperate. If it is full I would suggest in deleting memory of any useless apps or games, or invest in purchasing external hard drive or a larger memory Universal Serial Bus.
Now this is the final possible solution I could give you, if it is a disc problem. This is could be extremely difficult to do, but from personal experience 9/10 times it works.
Make sure to start with no disc in the drive and the Xbox is turned on. And you have a blunt object like your controller.
1. Turn the Xbox on its side laying down
2. Open the disc drive and put your disc in. Now close it.
3. Now while your xbox is trying to read the disc, just simply starting lightly-medium strength hit the top of your xbox in the general area of where the disc is until the xbox can read it or declares it can't.
This is won't necessarily work first try, but although it sounds stupid it does work for me.
May 23, 2014 | Video Game Consoles & Games
Xbox wont read discs
You will need to have the drive replaced. We can do it for you. We are a listed repair service on this site.
www.videogamerepairservice.com
Dec 17, 2012 | Microsoft Xbox 360 Console
I am playing Modern Warfare 2 on my Xbox 360 and after about 20 minutes it quits reading the disk. Any clue on how to fix this? Other disks work just fine.
Check the disc for any scratches. Clean the disc with some disc repair solution. If you just purchased the game try and take it back to where you bought it for an exchange. If there is no scratches or anything that could stop the disc from reading right it could be your Xbox. Xbox has been known to have many issues with heat maybe your Xbox is getting to hot. In which case the problem is your Xbox and you will have to call Microsoft about getting a new Xbox. My Xbox started to go bad in the exact same way. I would play multiplayer for awhile and it would freeze after playing for a little while. I would then turn the xbox off for a few min then turn it back on and it would work again for awhile untill a few days later when i got the red ring of death which means a hardware fail.
Dec 26, 2009 | Video Game Consoles & Games
XBox 360 disc reading error
try to clean off the eye of the consel. it could be dirty or scratched
buy a can of air duster (caned air) can be found at radio shack or wall mart. spray the can,wile the can is level, in side the disk drive and see if that helps
Dec 17, 2009 | Microsoft Xbox 360 Console
My 360 dose not read discs but it dose spin them
Disc Error :- I have the same error. You can do 4 things.
A) You have to keep turning it on and off. Here's how... Turn it on, then click open tray then close tray ( keep opening and closing tray about 10 times) then turn the console off. Then keep repeating process for about 15-20 minutes and eventually the game disc will show up. ( I have to do this every time)
B) Make sure that this is covered by Microsof't's RROD warranty. Then some how get teh red rings on this console and send it to Microsoft. (Note: I am not held responsible for your actions.)
C) This is a lens problem. So go out to a store and buy a DVD lens cleanser. It's a disc that cleans the lenses of the DVD or the XBOX.
D) Open it up and replace the lens (like the above guy said) (much harder and more costly).
Pls rate my solution if it did help thanks.
Jul 25, 2009 | Microsoft Xbox 360 Console
Does not read disc
use a dvd lense cleaner if that doesnt work take it to a game shop it prob the lasor.
Jul 15, 2009 | Microsoft Xbox 360 Console
Different disk read error
If other games worked then its the disc
Jan 18, 2009 | Microsoft Xbox 360 Console
Disc unreadable
sounds like dvd rom m8 try it on another console or try anther rom on yours first b4 buying 1
Nov 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
