Sony AA Nimh 2500 Mah Rechargeable Battery
Problem for Sony AA Nimh 2500 Mah Rechargeable Battery
Initial charging time
By lizzie0829 on Oct 09, 2008
I just bought 4 Sony AA Nimh 2500 Mah Rechargeable Batteries. How long should the initial charging be? and once used, how long should I charge it? thank you
Best Solution
posted on Oct 09, 2008
Very Helpful)
beergut707
Rank: Guru
Rating: 85%, 52 votes
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 14, 2009
Not Rated)
intrusion
Rank: Apprentice
Rating: 0%, 0 votes
i have got the batteries on chraging since 6 hours. they are still charging. so i guess that it takes 7 hours or more to charge the batteries
Was this helpful?
Yes
No
Solution #3
posted on Oct 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks beergut707.
actually, i found the charger's manual last night and it stated there that the charging hour is 7. but it depends on the Mah of the battery.
But, i do appreciate your reply. i'm not aware of ignoring the light inidcator. I usually pull the plug when it not lit. so maybe that's why my old batteries gets empty easily.
have a nice day!
Popular Solutions for Sony AA Nimh 2500 Mah
Questions and Unsolved Problems for Sony AA Nimh 2500 Mah
Do you recommend Sony AA Nimh 2500 Mah Rechargeable Battery?
Answer
Answer
I have a remington model REM50PV propane heater and i have to hold the fuel button all the time to... (More)
Answer
timer setting for yard lights???? can't find the manual... two buttons, the right one is for light... (More)
Answer
I nedd a schematic for a Yamaha 48 volt Golf Cart Battery Charger. Someone has removed the main... (More)
Answer
1 have a mariner 15hp 2stroke manual outboard engine.can i wire it up to charge a 12v battery
Answer
for how long is the charging of sony ni-mh 2500 AA rechargeable battery using a sanyo... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Electric Power... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
