Question about Motorola Cell Phones
My flex cable from the lcd to the keypad of my Motorola RAZR V3 has been cut. How would i replace this ?
    Master:
  • 383 Answers
Its a bit problematic trying to fix the strip as its a flap phone and you might damage the new strip as well as body parts trying to fix it ...... i wud recommed get it fixed from the authorised service centre as they have the proper tools and knowledge to do so
Posted on Oct 09, 2008
My motorola razor v3 has a white screen?
Hi, White screen on motorola razor phones can be caused by either the LCD or the flex of the screen.
First, you will need to check for the flex by replacing the flex of the phone. the flex controls the display of the phone and the keys on the keypads of the phone.
The LCD also can cause a white screen display. After replacing the flex and if it's still has white display,you will need to replace the screen.
Have a nice day.
Sep 16, 2010 | Motorola Mobility RAZR V3
Motorola RAZR V3 LCD SCREEN went blank - black screen
The LCD flex connector is very sensitive. 4/5 of the RAZR screens I see go out are due to a loose flex connection. It's super easy to fix it. Take off the battery door. There are two T6 screws. Take them out and pop off the bottom of the phone. There are two flex cables: one for the keypad, the other for the screen. Connect the flat cable (screen cable) first. Then connect the bent (keypad) cable. Put back together. Voila.
Aug 16, 2007 | Motorola Mobility RAZR V3
Retrieving data, broken screen
hi
The Phone needs a new Keypad flex and most likely a left hinge pin. When the phone is open, the cable runs through the left side of the hinge. It is very common for the hinge pin to become chipped and put a small cut in the Flex Cable.
You can get the parts on ebay. search for motorola v3 keypad flex, and motorola v3 hinge, or knuckle.
thankyou.
May 04, 2009 | Cell Phones
MY RAZR WONT LET ME DO NOTHING!
I think you need to change the main keypad flex cable on your phone. There is a slim chance that it might be the software. But I have seen it many many times that its the keypad flex.
Mar 17, 2009 | Motorola Mobility RAZR V3
RAZR
You need to replace the flexcable on the phone.
Jun 25, 2008 | Motorola Mobility RAZR V3
V3 freeze... same old.
Yup I agree.. I have the same issue going on with my Hubbys phone right this minute.. I have a Flex cable on the way for it.. Just the Keypad is lit on mine.. But the Flex Cable is the one cable that controls the LCD the side buttons and the key pad and yes its the cable you see running in back if you take the battery out.
Mar 17, 2008 | Motorola Mobility RAZR V3
Motorola razr freezing
your phone problem is the keypad flex of your phone'
you can fix it by replacing the keypad flex'
motorola dealer has the keypad flex'
ask for a skilled cellular technician to re-place your keypad fle..
i hope it will helf to your prob...
Jan 07, 2008 | Motorola Mobility RAZR V3
HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Dec 07, 2007 | Motorola Mobility RAZR V3
Screen not working
On a RAZR, there is a problem in the joint or hinge where the phone opens, and the flex cable that connects the two often comes loose. This can usually be fixed short term by pushing the halves of the phone together firmly, and then opening and closing the phone. Do this while the battery is out.
For a long term fix (or if that doesn't work), you have to take the phone apart. It would be best to take it to a repair shop for this.
Dec 06, 2007 | Motorola Mobility RAZR V3
Blank Screens
try reflash the phone or replacing the lcd
Sep 12, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
54 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
