Question about Jensen VM9510 Car DVD Player
Can u hook ps2 to dual xdvd700
It has red and white rcas but not a yellow i have sound but nopicture please help
  • 39 Answers
No you can not hook up a ps2 to the dual. It hads audio inputs but no video inputs
Posted on Oct 09, 2008
How to hook up the wii cords
First, you are posting a question about the Wii under the PS2 heading. Problem number one! Number 2! If your TV is new enough, it might not have the connections for A/V jacks like the yellow red and white. Here is how they connect. Yellow, video, Red, right sound, white, left sound(mono)
Jun 11, 2014 | Sony PlayStation 2 (PS2) Console
How can I hook up my ps2 to my Philips Magnavox TV?
First, you'll need a PS2 composite AV cable (Red, yellow, and white cable). If you don't have one, you can get one on Amazon for pretty cheap. (http://www.amazon.com/PlayStation-2-Composite-AV-Cable-PlayStation2/dp/B00004U8QX)
Next, plug the flat end of this cord into your PS2, and the red, yellow, and white plugs into their corresponding outlets on the TV. There may only be yellow and white outlets on your TV (in which case they will be on the front). Then, turn both the TV and the PS2 on and see if its working!
If you don't have red, yellow and white outlets on your TV, you will need an RF adapter for the PS2. (like this one on eBay (http://www.ebay.com/itm/RF-Unit-Adapter-by-Komodo-NEW-for-Playstation-PS2-PS3-/390624177322)
Hope that helps.
Jul 16, 2013 | Philips Televison & Video
Trying to connect ps2 to samsung syncmaster have connected the red and whie cables but all i get is a fuzzy black and white picture - do i need a different cable??
Is the cable you are using a set of Yellow, Red & White cables? If so do you have them plugged into the ports on the "side" of the Monitor? or are you trying to use the ports on the back?
It should be hooked up to the ports on the side.
Jan 05, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
How to test the xdvd700 before I install in the car. what wires go to possitive and what to negative
Hello there,
Well the wiring colors appear to be standard for most every piece of mobile A/V equipment out there.
Yellow = Battery Power(12V Positive)
Black = Ground / Battery Negative
Red = Vehicle On / 12V+ (or also hook it to the 12V Positive for "always on")
Here's the manual with the wiring diagram on Page 6(page 7 of the PDF):
http://www.dualav.com/support/manuals/xdvd700.pdf
I hope that helps
Mar 31, 2010 | Dual Electronics XDVD700 Car DVD Player
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
Need help on hooking up a xdvd700 dual without ebrake
i have the xdvd700 dual. my screen goes blank when it comes all the way up. is there a solution for that? or is that manufacture's problem?
Jan 30, 2008 | Car Audio & Video
Xdvd700 bypass code
How to get code xdvd 700 for dual model
Dec 27, 2007 | Jensen VM9510 Car DVD Player
PS2 connection question
by connectors do you mean a coupler? if so that should work. also verify that you are hooking the yellow (video) to an input and not an output.
Dec 08, 2007 | Sony PlayStation Portable (PSP) Console
Trying to get ps2 to play on new tv..
USE a VCR between the PS2 and the Sylvania TV.  Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4.  Set the VCR channel to Line 1 or Line 2.  This should work. I hope it helps you.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
Jensen VM9510 Car DVD Player Logo
151 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Iron
Iron
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
