Question about Panasonic Heating & Cooling
Exterior fan does not automatically turn off when air conditioner/heater is turned off. Must be turned off manually.
  • 958 Answers
Could be a stuck relay that control the fan. check the 24 v relay or 24V magnetic contactor. could be a welded contact also.
tnx 4 using fixya,
drcool
Posted on Oct 09, 2008
My Air Conditioner/Heater does not blow out air
Hi there, it's possible a fuse, check your fuse panel and you will find a fuse caller blower/fan, check that first, cheers
Mar 05, 2014 | 2005 Dodge Stratus - Coupe, with rear...
Exterior fan motor replacement
i would replace its run capacitor first.
Jul 04, 2013 | Ruud UAMB Air Conditioner
Fan isn't running
I am assuming you are talking about the exterior fan. Did you check the electrical box that should be next to your exterior unit? When you open it up there is a handle attached to an electrical bridge.
When you plug it in one way there is no electrical connection. If you turn it 180 degrees then there is a connection.
Jun 05, 2011 | Ruud UBHC Air Conditioner
The heater works but when the defrosters are
The Air conditioner compressor is seizing when the compressor clutch trys to engage. When you put on the defroster the air conditioner automatically comes on to take humidity out of air.
Jul 24, 2010 | 1996 Plymouth Breeze
Weather King blows fuse in Criterion II furnace
You probably have a shorted wire between the heater and the a/c. There are two wires that conncet the control power to the outdoor a/c from the heater they should be on terminal c & y in the heater. disconect those two wires and try it again if the fuse doesnt blow you have a short in the wire between the a/c & heater
Jun 01, 2009 | Weather King 10AJA2501AH Air Conditioner
Heater/air conditioning external slide broken. Where is the inner link?
Take your time and pull the dash apart piece by piece as to not break. Start on the passanger side. It will be close to your blower motor. You can turn it on and listen for location. Hope this helps.
May 30, 2009 | 1997 Isuzu Oasis
1972 moblile home heater does not work automatically
alot of times those switches go bad and poeple just by-pass them those switches operate in this fashion...when you put the fan to automatic it will only come on when the heat or cool is turned on when you put the switch to on the fan will run continueously ie the switch usually will be labled Auto- Off - On
Jan 06, 2009 | Heating & Cooling
Heating & Cooling Logo
167 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
