My printer is printing blurry, and my photos has a rainbow lines at top of pictures. I've did the cleaning, and nothing.
5 Suggested Answers
MJS_1
  • 150 Answers
SOURCE: Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Posted on Apr 24, 2008
gremlin11
  • 78 Answers
SOURCE: I have a canon pixma
rrenor,
You will find that the ink in the cartridge is low or almost out. If you haven't printed pictures for some time than the unit has still purged, which means to have sucked ink through the head, everytime you have turned it on. The long and short of this is that over time it has been emptying your cartridges. Nothing you can do about it, it is just the wayy these machines operate. Try checking the ink levels and if they are all full, leave the print head in park overnight and try again tomorrow, see what happens. If it is still giving you lines than it may need to have the print head replaced.
Don't do any more cleans now, you are just wasting your ink. Allow it to sit and you may find it will fix itself.
Gremlin11
Posted on Dec 11, 2008
ydja
  • 3 Answers
SOURCE: horizontal lines through my printed photos
Are you sure your ink is not on the verge of finishing? Try changing the colour ink and print again. Sometimes I take the cartridge out, shake the ink down just in the same flashing motion as I do my pen, then replace it. You may try that.
Posted on Jan 20, 2009
  • 27 Answers
SOURCE: Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Posted on Mar 05, 2009
micromend
  • 748 Answers
SOURCE: sony dpp-fp70 photo printer photos has a white line across top
Your photo ink cartridge may be defective.
Posted on Mar 29, 2009
Bad printing quality
First off, Turn on your printer, on your PC/laptop go to Printers and Faxes (you haven't said which operating system you use)
Find your printer icon, right click on it, select Properties, locate and find Maintenance tab, click cleaning/deep cleaning.
When you don't use your printer for a while, you must clean the head/nozzle , that's why you have blurry print outs.
Apr 12, 2014 | Canon Pixma iP2700 InkJet Photo Printer
Vertical rainbow lines coming out on pictures
Printhead is damaged, or you can try deep cleaning 3x, or get a toilet tissue which is soft, use 50% alcohol/water ratio press it to the head to loosen any dry ink then wife it down, if this fix does not work time to buy new ink cartridge.
Nov 20, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Photos have lines in the printed picture
There can be a number or reasons for this. The top to are that the printer may need re-calibrating or the print quality is set to economy/fast draft instead of photo which is great when trying to save ink but printing a photo requires greater detail and more ink. Printing will take longer too.
Hope this helps
Jun 30, 2012 | Brother MFC 420CN All-In-One InkJet...
Epson stylus Photo 2200
When printing from your pc after selecting print a box will appear with several options including printer preferences. Select this and you will be able to select best photo and the type of paper being used.
Jul 24, 2010 | Epson Stylus 2200 InkJet Photo Printer
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
Faint rainbow line of blue/orange/yellow at end of printed photo
You might try cleaning or unclogging the print head[s] with a drop of water or two onto the outlet from the print cartridge[s] and a drop of water or two onto the inlet orifice into which the outlet of the cartridge feeds the ink.
May 18, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
ON PHOTO PRINTING I GET A LINE ACROSS PRINT THAT LOOKS LIKE A RAINBOW CLEANING MODE MAKES NO CHANGE
When you print documents how do they come out?
It is possibly a scratch on the printhead so it would need service by an authorized repair provider.
Apr 10, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon i550 has has rainbow line in output
Even though you say you have ink, the "rainbow" line is usually an ink problem. Try doing a head clean process.
Right-mouse click on the printer and bring up "Properties". There should be a 'Maintenance" tab and one or more cleaning options and/or nozzle checks.
Sep 05, 2008 | Canon BubbleJet i550 InkJet Printer
Printing problem
you can select the best photo from the proprties for the pictures and draft for the text try this may soluve your problem
Oct 24, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
538 people viewed this question
k24674
