Question about Compaq Computers & Internet
Power supply has a short on the four prong plug for the cpu board. the four wires that goes to the cpu board are as listed black wires and two yellow wires. with this plug unplugged the computer turns on, but with it plugged in the computer doesn't even power up. which could possibly mean that this plug is causing some sort of short. the plug is located by the fan that is mounted over the cpu board if you are looking down on it while it is lying on its side. if so then the location of the four wire plug is exactly one inch below the left most rear corner of the fan. thats if you are looking at the pc with the base of it facing you. please help!!!!!
    Master:
  • 538 Answers
Sounds a lot like the auxiliary power for the other parts of the board..replace power supply
Posted on Oct 09, 2008
The power supply came with no manual. There is no P IV power lead. There are two aux power leads. (1) four wire (O,B,R,Y) and (1) six wire lead (B,Y,B,Y,B,Y) The original power supply P IV lead has four...
As you've noted you need two Black wires (Ground), and two Yellow wires (12 Volt),
for a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
If you are not using the 6-pin PCI Express power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
,rob the 4-pin ATX +12 Volt power cable connector, and wires from the old power supply.
Splice the wires of the 6-pin PCI Express to them.
Note:
Orange wires are 3.3 Volt
Red wires are 5 Volt
Yellow wires are 12 Volt
Black wires are Ground wires.
You need two Yellow wires, and two Black wires.
Or if you have a spare 4-pin standard Peripheral power cable from the power supply,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
,buy and use an adapter power cable.
Example,
http://www.directron.com/p4atx.html
Nov 27, 2010 | Coolmax Technology COOLMAX M500B 500W EPS...
Died. nothing comes on, so not dead drive. switched out power supply, so not dead power supply. the switch on the front - blue led only comes on when plugged in lower right two prongs of 8 (4x4). So, tried...
short power switch pins on mother board, reset bios, short green wire to black wire on ATX connector with all drives etc.. power cables disconnected to test power supply. i suspect you have a dead motherboard.
Jun 20, 2010 | eMachines ET1161-01 PC Desktop
Core voltage problems in 845gvsr
check the +12V supply(between yellow wire and black wire) at the 4 pin power plug connector for the CPU.
If there is no voltage then you will have to change the power supply(SMPS). Thanks
Mar 19, 2010 | Intel D845GVSR Motherboard
Need a diagram on convertng a three prong to a four prong plug.
you need to put the RED and BLACK wires on the terminals L1 and L2 these are the power wires,polarity doesn't matter either wire on either terminal/then the WHITE wire goes to the N neutral terminal/the GREEN or GREEN/YELLOW STRIPE wire goes to the metal case of the dryer as safety ground
Jan 31, 2010 | Dryers
I have a HIPRO HP-305 power supply. The green
the 4 pin connector is for cpu power. the hipro power supply are not very reliable.
Jun 14, 2017 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Cannot turn on cpu
when you say cannot turn on cpu - what do you mean - ?
cannot boot up?
try removing the cmos battery for a minute then replace and try again.
any error beeps ?
working fine before ?
Oct 11, 2009 | E-Machines eMachines Desktop PC
Power switch light is on but no other poweris getting through, changed the power supply but same problem. light comes on power button but power supply fan doesn't even come on.
No beeps are heard, no CPU fan is turning on, only blinking yellow light. This brand usually experiences this problem.
  1. First, check the power supply. Disconnect connectors from the board and make a jumper wire for the green wire to any black wire. If the PS fan does not spin then it's busted, else proceed below.
  2. Reconnect connectors except the one with 4 wires, 2 yellow and 2 black, then switch on. If CPU fan turns on then you have a bad processor.
  3. If the fan is still not turning on then check the USB port pins for short circuit.. disconnect it from the board and switch on.
  4. Do the same with other hardware connected to the board.
PS: The metallic casing of computers must be connected to the common ground of the power utility to protect it from stray currents that result to damage of sensitive components such as processors, memory and hard disks.
Sep 26, 2009 | Packard Bell (190169) Power Supply
Yellow light on power button keeps blinking but doesn't boot.
Sep 24, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
POWER ISSUES? OR MOTHER BOARD......
IT WAS THE POWER SUPPLY. AS SOON AS I PUT A NEW UNIT IN, IT BOOTED RIGHT UP... NO PROBLEMS YET AND IT'S BEEN ABOUT 20 HOURS. I WAS TOLD THAT A POWER UNIT WILL DO THAT BEFORE IT GOES FOR GOOD(ALONG WITH *********** BOARD)....
Aug 28, 2008 | Sony VAIO VGC-RB34G PC Desktop
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
