Question about Admiral Washing Machines
I want to know where i can get a pump (drain) for an admiral 560m heavy duty washing machine
  • 218 Answers
One source for appliance parts on line is www.repairclinic.com
Posted on Oct 09, 2008
The water is not draining out of the washing machine what could be wrong
not much info out there on this one
water pump solenoid or water pump
faulty control board timer
to empty machine run drain hose out the door
or towels and buckets
Sep 17, 2016 | Simpson Washing Machines
Hi, My Admiral 560 heavy duty washing machine has stopped washing and won't spin dry iether , it fills empties and gose through the motions of everything , but will not wash or spinn dry, what is that...
I had a similar problem with a maytag and it was the lid switch. I put a new one in and it worked just fine. Hope this works for you. Cost about 10 dollars.
Dec 24, 2010 | Admiral Washing Machines
Washer stops at the spin cycle and won't drain
check your lidswitch. do you hear it clicking when you raise and lower the lid.
Dec 10, 2009 | Admiral AW22 Top Load Washer
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
Admiral heavy duty washer - cleaning filter
Aw22 doesn't have one, remove the front panel to gain access to the pump, To do this insery a flat knife between the top panel and the front panel 4" in from each side to release the clips.
Unclip the two hoses to the pump after draining the machine, lower the external waste hose to floor level to drain.
tilt the machine back to remove the belt.
Remove the 3 bolts for the pump to remove and clean out.
refit in reverse order.
Jun 05, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
