Question about Dell PowerVault 120T DLT7000 DLT Tape Drive
AIT5 drive compatibility with SDX1-CL cleaning tape
We just upgraded our tape drives from AIT3 to AIT5. I noticed that we are still using SDX1-CL cleaning tapes in the jukebox and I saw listed on the container description only AIT1, 2, and 3. Is it permissible to use this cleaning tape with AIT5 drives?
The AIT-5 drive has its own cleaning tape (path cleaner).
Using an older path cleaner (sdx1-cl. sdx3x-cl, or sdx4-cl) will not work and could damage your drive. The correct path cleaner is SDX5-CL.
Posted on Dec 01, 2008
Dear Sir We rely on an external contractor to backup our data. We need to retrieve the data and got this reply: " [...] I have just been down to the computer room and checked. Your data backup is...
these tape cartridges are very slow to read & write. if u r reading a set of data & need to go back for certain data u have to rewind & wait & watch until that data area arrives. it takes a lot of time. in order to save time u need optical disk drives & dvds to backup your data. u can also ask them to convert your tape cartridge data into optical disks.
Sep 13, 2011 | Smead Manufacturing Company Sony AIT5 Tape...
DDS-5 not compatible with windows 2008
I am pretty sure that the driver should be compatible with win08.
If you are using backup exec then try switching to use symantec drivers for your tape drive (setting withing BUEX)
If it is just the tape that cant be read or identified and was backed up using windows backup then try restoring the backup on a 2003 server and then copying the data across the network.
May 10, 2009 | HP 364446-001 Storageworks DAT 72x6 DDS-5...
Seagate drive doesn't recognize tape media.
please try to use cleaning cartridge. if tape drive is still in failure. perhaps the heads is bad.
Feb 23, 2009 | Seagate Travan TapeStor Travan Tape Drive
Booting from a USB Stick
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download UBconvert.zip using this link - http://www.pendrivelinux.com/downloads/UBconvert.zip
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Dec 28, 2008 | Toshiba Satellite R15-829 Tablet PC
No Compatible media found in HP Tape Drive
Try a brand new tape fresh out the wrapper.
If that doesnt work make sure you are using the right drive in your backup software!
It sounds like a message often seen in windows backup where you have selected the wrong tape drive from the list and it just tells you "No compatible media found" when actually the drive listed isnt even connected to your system still
Nov 27, 2008 | HP StorageWorks Ultrium 448 LTO 2 Tape...
Wont accept cleaning tape
Make sure there are no pending jobs on the drive, if the drive is expecting a tape and gets a cleaning tape it will spit it out. Also, has the cleaning tape been used a lot? They have a limited life cycle and if they have exceeded their max uses they may not work.
Nov 13, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
Memory upgrade
you can use any DDR 180pin. But having two RAM of different speeds may not be compatible sometimes, so upgrade it to 1Gb by just using (1) 1Gb pc3200.
May 15, 2007 | EliteGroup P4VMM2 Motherboard
Dell PowerVault 120T DLT7000 DLT Tape Drive Logo
102 people viewed this question
Alun Cox
