I have a Toshiba 30" tube TV (30HF83). The HD picture is fine but now when I tune back to the basic programs the picture is purple and green.
  • rnbrown Oct 09, 2008
    I have a Toshiba 30" tube TV. I have a cable box with HD. The HD picture is fine watching TV and when I play DVD's the picture is fine. When I switch back to standard TV the picture is purple and green.
    I have a 30" Toshiba HDTV tube TV and cable with HD. The HD programs are fine but the standard are purple and green.
  • 4,472 Answers
First off I need to know exactly what you mean by basic programs? Is it the same box just different channels? Once I have more information I can assist you further. Please don't request more help until I am able to do so. Also what cables are you using to hook up these "basic programs"
Thanks,
Lee
Posted on Oct 09, 2008
    President:
  • 1,952 Answers
The colorization is probably magnetization of the shadow mask of the screen. The horizontl lines are from loss of the vertical blanking function (that stops the visibility of horizontal lines during the vertical scan of the raster).
So, first: Try deguassing the screen. If the deguassing coil on the set is working properly it should gradually remove the magnetism by switching the set on, leaving it on for one minute, then off, then repeat. If you have a loudspeaker (most often a subwoofer) nearby the tv, move it further away.
For the lines, the only way is to have a qualified service tech repair it. The blanking circuit is complicated in new sets (old sets it was merely a capacitor that needed to be replaced, but today it is buried in an chip function). You might try a hard reset to see if that help. Merely unplug the power cord for 4 hours.
This may help..... The age of the set precludes spending alot of money but check out the above suggestions to see where it leads. If the degaussing coil in the set is not functioning the repair is probably more that one might want to spend on a set of this age.
I like Toshibe products. Even at this age I wouldn't hesitate to fix it if it could be done for a very reasonable price, however.
this is degaussing problem
keep tv off for half an hour and if you have changed the direction keep it as it was.
if any magnetic thing is there near to tv remove it like speaker or headphone etc.
hope this will help.
    Master:
  • 505 Answers
Standard-definition TV signals (about 480 visible lines) are blown up to fill your HDTV screen (anywhere from 720 to 1080 lines). The original standard-def TV specifications were optimized for smaller screens than are common today.
THE FIX: Ask your cable or satellite installer to check if DTV signals are strong enough for your set-top box. If they're too wimpy, a commercial-quality inline amplifier (about $80) will provide the missing oomph. If you receive digital TV signals off-air, install a preamplifier (about $60) at the antenna to boost signal strength
THE FIX: If you haven't bought an HD set yet, here's a reason to wait: Future sets will be better at upconverting images to HD. Meanwhile, outboard video scalers can convert a 480i signal to 1080p. Models from Lumagen and DVDO range from $1000 to $2500.
    Genius:
  • 1,269 Answers
Are you using a satelite dish or cable? Try to play just a normal DVD and check if the same problem occurs. If it does, one of the bulb is needs to be checked. What you can try initially is unplug the power of your TV for about 2 hours then plug it back in. Check if that fixes it.
Toshiba rear projection TV
if you are seeing just green and purple color then your red crt is not working could be just a loose connection on the red crt socket or a bad red crt . crt meaning red picture tube.
May 22, 2013 | Televison & Video
My TV has a green / purple tint on the corners. Help?
It might be due to picture tube problem... As its too old, the picture tube might be weak and hence you might get colors at the edges.. Better replace the picture tube with a new one to solve this problem
Apr 01, 2012 | Bush Televison & Video
Hi. i vacuumed the back of my 9yr old toshiba tv to get rid of dust.when i put it on the volume does not work properly.i get some noise but not proper volume.plz help
Hello
During vacume back, some plug in connections may be got loose contacted, due to the suction power of the cleaner. You just open your tv, after unlug it from mains supply, and pull out and replug each plug ins, for two or three times. Again you feels the probelm is not resoved, inform me through Fixya. OK.
Nov 19, 2010 | Toshiba 30HF83 30" TV
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
No clear sound from speakers, even when volume is max out on toshiba model 30hf83 tv
Use a audio signal tracer to pinpoint the distorted sound location,you can use an amplified pair of computer speakers.Or request the complete 9mb 126pages schematic diagram from my personal server at computec40@hotmail.com
Nov 21, 2009 | Toshiba 30HF83 30" TV
Picture problem
I have the exact same problem a month ago. I replaced the two STK392-110 ICs with the STK392-110T adn everything went back to the way it was.
Jul 01, 2008 | Toshiba TZ50V61 50" Rear Projection...
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Color distortion
Problem on CRT board, this is the board on the back of the tube. It has a open transistor for the green.
Oct 08, 2007 | Toshiba 32AF43 32" TV
Tuning programmes on Toshiba 30HF83 30" TV Problem
Hello Skinno, Frist of all make sure that you are set to Antenna input and then connect your antenna to the TV this will pull in the VHF ansd UHF channels. Then perform the auto channel select. If this does not work perform a manual channel selection this should clear up your situation.
Sep 03, 2007 | Toshiba 30HF83 30" TV
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
