Question about Fisher and Paykel DGGX1 Electric Dryer
Fisher & Paykel Electric dryer wont tumble
I have a 4.5kg F&P dryer, model number ED56. It sometimes decides it wont tumble. I have to open the door and turn the drum then it will work. Sometimes I have no problems. I only need to have a sheet in it and I still have the problem. F&P want $125AU just to come out and look at it. Can someone help me out.
  • pb66 Oct 31, 2008
    Mine started with the same problem...sometimes shifting the weight of the clothes inside helped, however it now just refuses to turn at all!
  • 3 Answers
I had the same problem,fixed it today with a replacement capacitor,cost $10 2nd hand (only cos I couldnt find a new one today and wanted it fixed now!)Unplug appliance, took off the back panel,underneath the motor on bottom left is the capacitor,remove the 2 wires, pull the capacitor out its bracket,replace,refit the 2 wires,replace back panel and Badabing Badabang!! My machine is working to full capacity again.
Pays to check out these forums doesnt it!!!
Posted on May 18, 2009
    President:
  • 1,462 Answers
Fault is almost certainly the motor capacitor - usually mounted on the motor. cheap part and should be available from a good spares stockist
Posted on Oct 09, 2008
Whirlpool electric dryer wont run. the light comes on when the door is opened so there is electricity running to the dryer
check the door switch to see if it's broke,then check to see if you have 240 volts going to the dryer inthe back where the cord connects to it and also i need the model number
Sep 21, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
F&P ED56 has 2 problems
Yes, (2) certainly sounds like the start/run capacitor has failed. You will see it has a split or bulging case, or a displaced end cap. Replace it with one of the same voltage rating and capacitance.
I can't advise you on (1)
Jun 20, 2013 | Fisher and Paykel Dryers
My F&P ED56 dryer just hums when it is turned on. The lights come on and it hums, but it doesn't turn or blow air. We have checked the belt (that is OK), the drum can spin by hand, there is no lint...
sounds like it maybe the motor, here are other reasons the drum won't turn and how to open the dryer. Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 28, 2010 | Fisher and Paykel Dryers
Fisher ED56 dryer wont turn off!
HI, this will occur if the timer control module or control board has failed. replacing the timer or control will fix this issue.
thank you,
vijay (vote for me)
Sep 24, 2009 | Fisher and Paykel Dryers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel ED56 Dryer alarm on. Nothing else works
Replaced electric control panel. Looks like power spike fried the works
Feb 27, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DGGX1 Electric Dryer Logo
782 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
