Question about Epson Stylus C63 InkJet Printer
Epson c63 stylus clogged nozzle
This happens on a regular basis. I use only the genuine ink cartridge but just the same, horizontal banding occurs, especially if it (printer) is not used for sometime. Can you please help me on this one. What cleaning can I do?
Don't let it sit idle for very long periods of time
Posted on Nov 06, 2008
My Epson Stylus NX400 won't recognize any of the ink cartridge after I performed a head cleaning and nozzle check option. There are still ink inside and they are original genuine ink. What should I do?
Did you remove the ink cartridge when you did the head cleaning and nozzle check, if so, did you touch the copper circuit chip on the cartridge? . . The chip is normally what tells the printer how much ink is remaining in the cartridge and if it cannot read this, it may not recognise that the cartridge is genuine and still has ink remaining inside. . . .You can try cleaning the chip with a soft dry cloth otherwise you may have to install a replacement cartridge. . . See http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=106004&prodoid=63075469 for the User Guide showing how to replace ink cartridges for this printer.
Sep 19, 2011 | Epson Stylus NX400 InkJet Printer
I replaced all of the cartridges with Epson, but the black won't print. After some nozzle checks, black is getting low and STILL no black printing occurring... what going on? Now the other colors are...
Nozzle cleaning uses a lot of ink, that's probably why the other ink cartridges are registering low on ink. Are you using refilled cartridges or brand new? Also, have you had the cartridges for awhile? I've found that the nozzles can become clogged either from not using the printer for awhile or because it's a recycled cartridge that didn't have the nozzles cleaned before it was refilled. When that happens, unfortunately, sometimes it takes a lot of cleaning cycles before the printing comes back. Let me know more about the cartridges you have.
Mar 03, 2011 | Epson Stylus CX7400 AllinOne InkJet...
C63 epson printer cartrige. I refill the black ink but when I install it, the button indicate red button . I could not print the document. Some of my friends said that I should reset the contact points....
Yes it is so happen, that's the disadvantages of not using genuine ink.... If I were you use genuine cartridges.. and if you were to think to lessen you expense tried to refill it with the people who knows refilling... maybe you just destroy your cartridge... because when you refill it full the tendency is to ruin the cartridge.
Jan 09, 2011 | Epson Stylus C63 InkJet Printer
My printer is leaving horizontal streaks across
When I had the same problem, I found out, that Epson did not like Generic Ink. As soon as I replaced it with Genuine Epson Ink, it was fine.
Make sure you do Maintenance, Nozzle Check and Head Cleaning. You might be clogged?
Good Luck.
Nov 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Apr 22, 2009 | Epson Stylus C86 InkJet Printer
Epson photo 995 - black ink not printing
This is a common problem I have found with Epson printers. If you don’t use the printer on a regular basis the printer heads can clog. I have found no way to clean the heads once this occurs. I will now only purchase HP printers because the printer heads are part of the ink cartridges. With every cartridge change you get new heads, end of that problem!
Mar 09, 2009 | Epson Stylus Photo 895 InkJet Printer
Horizontal banding on prints
try aligning the print heads before cleaning them
Oct 10, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus Pro 9600 horizontal banding problem
the banding is a result of clogged head. I had the same problem and fixed it with many cleanings.
Jul 12, 2008 | Epson Stylus Pro 9600 InkJet Printer
No yellow ink
It sounds like you have a clogged nozzle. First I must assume you are using refilled compatible cartridges. You should change the cartridges for genuine Epson ones before proceeding.
Run 4 or 5 head cleaning procedures through the printer driver. DO NOT DO THIS WITH COMPATIBLE INK IN as this can make the problem worse.
If the clog does not clear or show significant improvement after 3 or 4 cleans, contact this person for information on intensive head cleaning for your machine.
Mar 27, 2008 | Epson Stylus C43SX InkJet Printer
Epson Stylus C63 InkJet Printer Logo
118 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
