Question about HP Photosmart 3210 All-In-One InkJet Printer
Looking for power cords and usb
I recently was given a HP Photosmart 3210xi (3 in one) but I dont have any of the power cords usb or any other connector I my need. and I cant find which one I need online
  • 70 Answers
It should be just a regular computer power cable and usb cable to connect to you computer
go to
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=447851&lc=en&cc=us&dlc=en&lang=en&cc=us
and print out the setup manual for your machine
You can also get the drivers you may need
on the left side click on software & driver downloads
Posted on Oct 09, 2008
Error code 0xc05d0381......what is it and how do I remedy?
Please try performing the steps given below
1. Without turning off the product, disconnect the USB cable from the rear of the product 2. Remove the cartridges from the product 3. Wait for the 'Insert Cartridges ' message to display on the control panel. 4. Disconnect the power cord from the back of the product. 5. Wait 60 seconds. 6. Reconnect the power cord. If the product does not automatically turn on, press the Power button c01602202.gif 7. Reinsert the cartridges, and then close any open doors on the product. 8. If you receive a prompt to print a calibration page, do so. 9. Reconnect the USB cable to the rear of the product, and then try printing again.
Oct 21, 2010 | HP Photosmart 3210 Printer
I own the HP Photosmart 3210 all in one printer scanner copier. I am getting the message 0xc18a0401 and cannot resolve with methods online with hp or separate.
Please try to perform the steps as given it will resolve your issues------>
  1. Without turning off the product, disconnect the USB cable from the rear of the product. NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
Aug 18, 2010 | HP Photosmart C6180 All-In-One InkJet...
My HP Photosmart 3210xi cartridge door is also locked in open
There's no sensor, it's just a spring and a plastic wedge thing.
Using a #10 torx driver, remove two screws holding the right-hand side panel from the printer. (one in the back, one on top underneath the ink access door.) Unsnap it and set it aside.
Disconnect 3 small ribbon cables and one 5-pin connector that lead from the printer to the access door/scanner.
Remove the lid from the flatbed, then remove the access door from it's hinges. Use the torx driver and unscrew the hinges from the main scanner body.
Lift the hinge assembly from the scanner and push the steel pin out, seperating the two parts of the hinge.
From there you should be able to loosen them up, remove the springs, lubricate them, or find whatever the problem is.
Reassemble and you're done.
Jul 16, 2009 | HP Photosmart 3210 Printer
HP 3210 Ink System Failure error code 0xc18a0307. Does any one have a real solution? Have already tried the lame instructions from HP. Like when you hold down the two keys at the end of the #'s pad and...
I have the HP Photosmart 3210 All-In-One with this stupid ERROR 0xc18a0307. I didnt purchase this printer, my uncle gave it to me and told me how much it was worth. That was enough to motivate me to try and fix it. Im not an IT guy or computer geek..probably just lucky...Maybe it was this "L.A Confidential Kush" weed!!! : D
My uncle gave this printer to me w/o the yellow cartridge so i went to Best Buy and bought HP Photo Value Pack for like $40. Before i did the steps mentioned below, I pretty much did everything that you could find as a troubleshoot process and it failed. I then decided to remove the cartridges and open up the ***ing printer and tried to get to the sprayers so that i could use the CRC Mass Air Flow cleaner ( I spent 6.99 for it at Auto Zone. as a last resort.)When i noticed how complicated everything was getting ( it totally killed my high!! ) I said **** it and re-assembled the damn machine. Before I started putting everything back i noticed that the white plastic spocket was off of the metal hex plug that is connected on the left side ( if you are facing the front of the printer while its taken apart ) so i placed it back on carefully and continued the re-assembly ( i dont know if this was the cause of the ERROR 0xc18a0307, but previous suggestions mentioned that it might be a mechanism failure.) After I was done putting everything together I put the cartridges back, plugged in the power cable from the back of the printer first, and then i connected it to the power outlet. I then connected the USB cable to the back of the printer but i forgot to plug in the USB to the CPU ( as mentioned below ) Then i did this ****....
( and i did this with everything connected except the USB cable, only because i forgot it was disco'd from CPU )
1. Put all the cartridges back into the printer. ( only if you didnt already do it after reading my story )
2. Press and hold down the four buttons at the same time:
OK, Cancel, Black, Color while the printer is off.
3. Then you hit the POWER button ONCE and then hold it AFTER it blinks or turns on and release the four buttons. DONT LET GO OF THE POWER BUTTON!!
( it might show that its resetting but i dont remember )
4. hold it for a full minute or until the copy button turns on
( i dont know what happened first because i was stoned and i started thinking about what i was going to do first if this stupid sequence worked, >8 D )
5. The copy button will light up and you will get a menu that asks your preferences.
6. Go thru the preference selection and then when your done hit the copy button with something you could copy in the scanner. Select number of copies and It should start to copy if the process worked. ( you will see the display in the cool little screen that says " Copying...." if not, try it over and over. you might find another way to fix YOUR problem.
Then i printed a doc from my computer and it worked.
After that, I scanned something to my computer and it worked.This is all i was able to try since i dont have a landline!!
I wish everyone luck with thier HP Photosmart 3210xi All-In-One!!
May 01, 2009 | HP Photosmart 3210 All-In-One InkJet...
Printer gets error 0xc18a0106
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 15, 2009 | HP Photosmart 3210xi InkJet Printer
Dont know how to upload pics to computer
after connecting your camera, power it up. the computer will then prompt new hardware found and is ready to use. in most cases, the camera will be treated as another disk in your computer (like usb disk). go to my computer and check if there is a removable devices listed. open that drive then you may start to copy and paste it on any folder of your computer.
the camera should also come with a cd, which you may install in your computer.
Oct 31, 2008 | HP Photosmart M425 Digital Camera
One more time?
sir is this model HP Photosmart 3210xi All-in-One?
or
HP Photosmart 321 -xi All-in-One??
because HP has either A321 else 3210xi
and if it is
HP Photosmart 3210xi All-in-One then click here for the driver link
select your proper vista and then install it in your system...
Aug 13, 2008 | Office Equipment & Supplies
HP Photosmart 3210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
