Question about Mitsubishi VS-45607 45" Rear Projection Television
Mitsubishi VS-45607 my tv shuts off on a regular basis. it may do it after a few hours of use or ten minutes. it might turn back on after a few minutes or an hour. i hear a click when trying to turn back on. for awhile it seemed to help if we removed the back and let a fan blow cool air in th back of the tv, the tv would come back on ,but nowthe green power light come on momentarily, clicks and then goes off..Do these tv's have a power supplyand if so could it or another part become heat sensitive and cause the tv to shut off?
  • 905 Answers
There is a protection circut that will shut down the tv when it detects a failure in one of the components , when components heat up to much they go into thermal breakdown, the part that is heating up and failing is getting worse , so it will need to be test to determine which one
Posted on Oct 09, 2008
Mitsubishi VS-45607 turns off immediately when I try to power up
STK ICS replace Both of them STK393-570 big black ICs will have STK on them Call mats for parts 1-800-628-1118
Dec 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
NEED TO REPLACE BULBS IN mITSUBISHI VS 45607 cAN NOT FIND THEM
This doesent sound like a bulb problem to me at all! it sounds like a few capaciters need replaced! Look put the screwdriver down and call a pro because you could ruin the set trying to do a minor fix and causing a major problem!
Dec 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607
YOU HAVE THE DREEDED CAPACITORS GOING OUT...AFTER A FEW YEARS-THE CAPS LOOSE THERE PURPOSE AND DEPENDING ON WHAT CIRCUIT THERE IN --YOU WILL SEE THE ASSOCIATED PROBLEM,,,EXAMPLE--COULD BE SOUND ,PICTURE (YOURS) OR VERTICAL(PICTURE CLOSING UP) ETC... YOU CAN HAVE CHECKED BY A REPAIRMAN BUUUUT ,MAY NOT BE COST EFFECTIVE ,,TUNICA
Oct 24, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Can't find any one to fix my tv
the following link may be able to help you diagnose your problem, they are mitsubishi experts.
Just leave them a email with your model number and what its doing.
http://servicemanuals.vstore.ca/
Oct 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-4541
clean it out it is over heating, use a air hose to blow all the dust out
Sep 01, 2008 | Mitsubishi VS-45607 45" Rear Projection...
VS-45607
sounds like a defective cappacitor or leaky diode in the deflection circuits. Unless youre comfortable working around the high voltage circuits of a rear projection set, it may be best to call a reputable repair facility that is famillair with mitsubishi products.
Jun 15, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV keeps shutting off
Push the menu and inputs buttons on the set in both together and hold for 8 seconds this should make the led flash a two digit code. Let me know what happens after doing this test.
Apr 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi Big Screen VS-45607
probaly bad wiring or shorts in the wires or something is intefearing with your tv if it is wiring it might be a fire hazard
Feb 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
108 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
