Sanyo flat screen tv , model #ht32744
The color of the screen has a green tint
5 Suggested Answers
  • 71 Answers
SOURCE: sanyo 42" flat screen tv green light comes on but no picture
oops u r in trouble.
Posted on Mar 05, 2009
  • 108 Answers
SOURCE: The TV works fine but the screen is green. Color
LCD television sets dos'nt have crt's, but ofcourses out of the RGB circuitry, R & B circuitry is'nt working or its not receiving the proper signals, that's the reason you see only green color,
If you are feeding the signal thru DMI/RGB cable from your set-top box, check for cable loose contact, cable wear-out, if you are feeding the signal thru coaxial cable its problem within the TV's circuitry.
Posted on Jul 29, 2010
  • 6 Answers
SOURCE: my sanyo plasma flat screen tv will not come on....
For what it's worth, you can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. I uploaded it here when I had some issues with this TV last year. The solution almost always seems to be to replace the Power Board and the Upper and Lower Y Buffers. The parts and costs (from Sanyo in July 2009) are listed below (NOTE: Sanyo will not ship these parts to anyone but a repair shop):
1. V4 Y-Main (Y-Sustain) Circuit Board (Part # LJ92-01200A, Alt Part # LJ41-02759A) - USD $139.00
2. Upper Y-Buffer Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3. Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD $64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for parts to USD $277.50. From my research, a shop would probably charge between USD $500 and $700 to do this repair. FYI - there is a class action lawsuit pending against Sanyo for this issue. The V4 Y-Main (Y-Sustain) Circuit Boards fail VERY frequently in this TV due to overheating. Hope this helps.
Posted on Aug 07, 2010
budmrtn
  • 11361 Answers
SOURCE: my flat screen sanyo tv screen wont turn on. the
Try disconnecting the connector KBL on the main board as shown in my picture #DSCF0585 to see if the backlights will come on, if it does, the main board is bad.
Also check the voltages on the output connectors of the power supply.
http://s807.photobucket.com/albums/yy352/budm/SANYO%20TV%20DP26649/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Dec 24, 2010
Green Screen on an HDTV
I do not believe there is any easy fix to this. The problem may be either in the picture tube or the related circuitry. The worst case scenario is the tube itself is failing. However, it could be as simple as a defective connection on the pc board at the tube for example. You may want to get a technician to check it out and get an estimate before you buy a new set. Good luck
Nov 25, 2009 | Sanyo HT32744 32" TV
Got a green tint on left side as i view tv
is this wen you look at the tv from another angle, is this a lcd screen ?
Jul 28, 2009 | Sanyo HT32744 32" TV
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo TV - HT32744
Lower the contrast first.
If colors not in balance, reduce saturation until "normal" to your eye with whichever color (or color pair) out of balance.
Aug 19, 2008 | Sanyo HT32744 32" TV
TV problem
Sound like either the Red or Blue driver transistor on the CRT board is intermittant.
Hope that helps...
Geno
Apr 03, 2008 | Televison & Video
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Black pic on tv turns green
normally this means the high voltage preamp green control transistor on the neck of the tube circuit board is loose solder connection from heat or is going bad.
Feb 17, 2008 | Sanyo HT32744 32" TV
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Green spot on the screen.
is there a speaker from a stereo player near the set? i noticed mine give my tv a greenish tint on the side of the tv closet to the speaker
Aug 05, 2007 | Sanyo HT32744 32" TV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
