Question about Panasonic NN-T694SF Microwave Oven
Loud pop and now doesn't work
The microwave was running for 2 minutes on high. There was a loud popping sound. Opened the door and it seemed normal. When the door closed the fan ,turntable and light came on. Could not stop it without unplugging it. When it is plugged back in the fan turntable and light starts immediately, and the display shows the welcome screen. the only button that works is the stop/reset, and when you press it the screen goes blank. Any help would be appreciated
David Ferguson
  • david622 Oct 20, 2008
    The model is NN-T694SF
    Thank You
    David Ferguson
  • William Miller
    William Miller May 11, 2010
    It sounds like you have a shorted door switch, a damaged door switch mount, or a shorted relay or other component on the control board.
    What is your model number?
  • Panasonic Master
  • 8,973 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can order Panasonic parts from Tritronics but if you only need a switch, you can order one from us for $5 postpaid.
Posted on Oct 21, 2008
What could cause loud popping sounds?
The sounds you are hearing is the defrosted water, from auto defrosting, running onto the hot compressor. This evaporates the defrosted water. This is quite normal.
Mar 23, 2014 | Samsung RF260BEAEWW
Electrolux microwave model fgmv185kfa made a loud pop and now won't heat anything and sounds louder than normal when running. Everything else seems to b working fine
SOUNDS TO ME LIKE YOU BLEW A FUSE WHICH IS INSIDE THE UNIT. IF IT'S UNDER WARRANTY TAKE IT BACK BECAUSE IF YOU OPEN UP THE CASING & FIX YOURSELF THIS VOIDS ANY WARRANTY
Dec 24, 2012 | Microwave Ovens
I have a microwave that is not working, I started it and a loud pop and smell happened. Everything is still working, the lights, the motor, the clock, the ventahood, but doesn't cook anymore.
Hello & Welcome to FixYa
The loud pop sound is caused when either it is a bad fuse or the high voltage capacitor itself has gone bad and needs replacement. As everything is working fine so the problem seems to be either with the door switch or the high voltage capacitor that is bad. Please check the door switch if that appears to be fine then to replace the high voltage capacitor you'll have to take it apart completely. Please get back to me if you have any other questions.
Kevin
Dec 22, 2010 | Kenmore 63792 Microwave Oven
My goldstar above the stove microwave popped and now won't heat. Everything else on the unit still works. Is this a problem that can be repaired? Thanks.
Did it make a loud pop like a firecracker?
Sounds like the High Voltage Diode shorted out and it probably is making a low or loud growling noise now..... ???
Sep 11, 2009 | Microwave Ovens
Not working plmv169dc
HI, the sound you herd was the noise filter and running diode. these important components have failed at this point. you will need to replace these components asap, if possible. this will fix your issue.
The Magnetron Cut-off fuse will need to be replace as well. this will blow if there is a malfunction within the unit.
Jul 22, 2009 | Frigidaire PLMV169DC Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave made loud popping sound and now does not heat.
Hey,
Try this
Probably a high voltage diode popped because contaminated grease eventually built up and made a path for a high voltsge arc to occur.. To confirm,take the outer cover off the microwave and discharge the high voltage capacitor by shorting its terminals. Then pull the plug off the magnetron side and place it near the magnetron socket. Now turn the microwave on and push the connector on the magnetron with a chopstick or a long insulated screwdriver. If no arc when you do this this confirms a bad diode.
please rate my suggestion..
Apr 13, 2009 | Kenmore 62702 Microwave Oven
Loud pop with smoke
Don't know why just plugging it into a new outlet would cause that unless you have a problem with that outlet. Sounds like it may have burned out the low voltage circuitry. I would advise having the outlet checked and certified safe before plugging anything else into it. Also, it sounds like the oven is toast, (Sorry!)
You can get parts on-line from AppliancePartsPros.com/Parts
May 23, 2008 | Emerson MW8107WA Microwave Oven
Microwave made loud popping noise
The magnetron is bad. Probably cost about $50 or $60 for the part. Not too easy to replace, but it can be done.
Dec 13, 2007 | Whirlpool MH7130XE Microwave Oven
Panasonic NN-T694SF Microwave Oven Logo
141 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
