I have a 2004 Odyssey LX. a CD has got stick in my stereo and won;t come out by just pressing the buttons.
How do I reomve the CD?
Thanks
I had a similar problem with a different van. I called the dealer and they told me to try putting another CD in partially and the pressure from that CD should make the other CD release. Just remember to keep a grip on the CD you are trying to insert. It worked on the van I had. It's a cheap idea to try....what do you have to lose?
This will have to be taken out and serviced. Unless you have some tweezers that will fit in there and force it out.
You need to wait for your car's stereo to cool down. If you used it for it for an extended period of time, it may have gotten hot and the ejection device may not respond.
Hold down the eject button.If you can hear the mechanical ejection noise. If your car stereo is making this noise, it is more than likely that the CD is just sticking inside the CD player and you can try and grab it with your had and pull it out .
Look for a hole the size of a pin on your car stereo's CD player. This hole is very small and looks similar to one on a CD-Rom drive, after locating the hole, use a pin and attempt to manually eject the CD. Now in case you have a factory stereo.
Hope this will help you out.
