Question about Apple Computers & Internet
Hard drive and dvd rom stopped working after changing to cd-rw, the ide cables have to unplugged to get any response from hard drive or dvd rom
  • djeffs Oct 09, 2008
    I have checked all cables, the dvd-rom was set to master and I made sure the cd-rw was set to master as well, after installing the cd-rw I booted the machine up which by the way was running fine, OSX 10.2.8 the boot up froze on me so I reset the boot up and then nothing. After putting the dvd-rom back thinking that it had something to do with the cd-rw still nothing. To get the dvd-rom door to open I have to un-plug the ribbon cable, same as hard drive, to get it to spin up properly I have to un-plug ribbon cable. I have bad feeling that the mother board is toast. Any other suggestions would be appreciated as I am new to Mac's but am A+ certified with PC's and a network administrator, Microsoft certified.
    Guru:
  • 558 Answers
Have you done the proper connection ? Please check out the Power & Data cable inserted firmly in Hard Disk, and DVD rom, after then check out the jumper is inserted correctly.
Unplug the Ram for 5 minutes and then try to start PC. Hope this works. Let me know the status after then.
Posted on Oct 09, 2008
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
I installed a LiteOn SOHR-5239v cd-rw drive. It doesn't show up on my computer and i looked on the website and couldn't find the driver.
Ok thats probably your problem. J
You will have to remove the DVD drive once it is removed look at the back it will look like this,
I have indicated where the jumpers are located. The jumpers tell the computer how to read the drive (every IDE drive hard drive, cd/dvd rom, floppy drive has them) the options are Master (meaning it is the main drive), Slave (secondary drive), and Cable Select (the cable decides how the drive will be read).
There are two ways to connect the drive to the motherboard one is to split the IDE Cable with the hard drive the other is the drive has its own IDE Cable and plugs in next to the hard drive.
If you are sharing the cable with the hard drive configure the jumper as Cable Select,
If your drive connects with its own cable select Master.
To do this pull out the jumper and insert it in the location you want.
Jan 19, 2010 | Lite On (SOHR-5239V) CD-RW Burner
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Can't reboot Compaq/Presario desktop, (power supply is working)
    If the system recovery disk doesn't work it usually mans that the hard drive is bad. I would change the hard drive and use the system recovery disk on it after replacement.
    Dec 27, 2008 | Computers & Internet
    When I put a cd r in my burner then press burn selection then it
    Try downloading a program called " RadarSync" it works like driver detective, might possibly help you out.
    www.radarsync.com/
    Dec 19, 2008 | HP (346789-001) CD-RW/DVD-ROM Combo Drive
    Cd rom drive
    Hi
    Please use the Cd/Dvd Drive with the following specification:
    CD-ROM/DVD-ROM/Disk drive
    8X max DVD+/-RW Drive with DVD+R double layer write capability
    Or
    16X DVD-ROM drive, 16X/10X/40X CD-RW drive
    Regards
    ELLIN
    Sep 20, 2008 | Dell Dimension 8200 PC Desktop
    Dvd rom
    Try to check the IDE connector and power supply of the DVD. also check the jumper setting of your DVD whether its slave or master. good luck!
    Jun 17, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
    DRW-1814BLT compatibility with IDE hard drive
    put hard drive as Master. dvd rw as slave!
    if DVD comes with sata then just put hard drive as master.
    configure it on the bios setting!
    if it still don't detect it
    try replacing IDE cable and sata cable!
    Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
    CD/DVD ROM disappears
    I would think either your IDE cable is faulty or the IDE connector on the motherboard, try swapping cables or use a double IDE cable on IDE 1 connector. You may have a faulty drive ide connection input in which case a new DVD Rom is the answer, only cheap nowadays.
    Nov 07, 2006 | Samsung (SC-140B) Internal 40x CD-ROM...
    Computers & Internet Logo
    213 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
