Question about Mitsubishi WS-73903 65" Rear Projection Television
Replaced Convergence but pictures still display with double images
I've replaced the 2 Convergence in a 73" WS-73903 Mitsubishi TV. However, the Red & Blue lines still won't lineup. The picture's displayed with double images and rainbow color on the sides of the screen. I've read from someone's posting about replacing the output amplifier. Is that a different part that need to be replaced or is it part of the Convergence? Does anyone have some suggestion or ideas?
I went to converge my mitsubishi ws 73903 and the blue line wont go down to match the other ones
Posted on Oct 29, 2008
My mitsubishi 55" has double
Tv have a problems known as a convergence problems,it dead.The tv convergence board must be replacing parts to solved the tv picture convergence problems.U have all the tools like a soldering iron,desoldering pump or a roll desoldering braid and a roll of solders?Can u also do basic soldering works?Yes,to all these answers.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to do the repair ur self.Or the shop,will cost u like $300-350 for parts and labors.
Jan 17, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The picture is showing a double image and is distored.
The problem you are refering to is more than likely a convergence problem. The convergence circuit in your tv is controlled by an IC (integrated circuit) stk392-110 and it makes the 3 colors (red, blue, green) line up/converge together to create a clear picture. You'll know when this part needs to be replaced because the picture you see is 3d looking and possibly bowed on the top or bottom or on the sides in any or all 3 colors.
Jan 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-73903 73" red convergence is stuck and won't move.
I have to presume you have got the model number wrong--WS-73903 does not show as a good model number.
Correct model number will be on the back of the set along with month, year the set was made.
If you have a convergence problem with the valid model number I can tell you what parts need to be replaced and in many cases I have Start to finish, step by step instructions for this repair.
The instructions based on model number are free and if available for your model I can post them here for you.
If you are not able to do the repair most shops are going to charge 300 or more for this kind of repair--all the parts usually needed can be purchased on Ebay for under 30 dollars.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 10, 2009 | Mitsubishi WS-73903 65" Rear Projection...
Can't aline the vertical red and blue on the left
The Convergence circuit has failed. It is recommended that a professional do the job.
The Convergence IC's need to be replaced.
It will be a STK393-110 or a pair of STK392-570's.
Hope this helps,
skyassoc
Jul 16, 2009 | Mitsubishi WS-65819 TV
Help, Help, Help! Mitsubishi 73" red convergence fiasco
Thats the time you need to replaced the convergence IC.
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry and fuzzy images .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and cannot be adjusted this is the symptom for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Mitsubishi WS-73907 TV
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
WS-55819 Mitsubishi Rear projection TV Picture goes blurry
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
Feb 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi platinum plus ws-55857
Solder connects = temporary fix.......Replace IC's..best
order two STK392-570 good quality.....16 to 22.00 each
...............................T.
Dec 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
219 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
