Question about Palm Treo 500 Centro
Power up prob
My phone was trying to sync up and wouldn't do anything else. i took out the battery and it wouldn't turn back on again. tried a hard reset still nothing.
  • butterluv06 Oct 17, 2008
    My phone was trying to sync with my laptop and wouldnt let me cancel the sync.....it jus kept trying over and over.....then i took the battery out and tried the master reset and the power light was jus lit like i was charging the phone.....now the screen wont come on and the power light is still lit but my phone wont do nothing.....
Man, I feel your pain. I've had the exact same problem. The only thing I've figured so far is to let the battery totally run out. Then, when you turn it back on, the phone/text functions return to normal. However, if you so much as attempt doing anything else, you'll be back to square one.
Posted on Oct 15, 2008
LG Rumor 2 turning on and off.
First, make sure if this problem appear after you install any APP, if so you can try to brush system to fix it.
Else maybe the following cases:
1, mobile phone motherboard leakage lead the current too large.
2, The inside circuit protection of the lithium battery is too sensitive, so it power off when circuit is large.
3, the battery itself is aging.
4, Battery contacts are dirt-bit, causing bad power supply.
5, The engagement between the battery and the phone is easy to loose bits. (try to remove the back case and press the battery then try to turn on it to see if it also turn off and on). If so, just make a piece of paper to stand the battery up
Of course, don't forget to see if the power button is back to its own place
Apr 08, 2013 | LG Rumor 2 Cell Phone
Wont Display Anything , Black Screen !
The screens brightness might be set to the lowest number as a joke. Try to change that.
Dec 09, 2011 | Texas Instruments TI-84 Plus Silver...
My phone turned off randomly and now it won't turn back on,thinking it was dead I plugged it in using the USB charger because I lost the other one...but after plugging it in it still wouldn't turn...
First of all change your battery and try again if nothing happens don't do anything just go to service centre with a photocopy of purchasing bill.
Aug 04, 2011 | HTC Cell Phones
My motorola Q9m won't turn on at all. I've tried everything..Took the battery out and put back in, it won't turn on at all.
I had the same problem. We took the battery out twice and put it back in and it did not do anything. A third person tried taking out the battery and putting it back in and the phone works fine now.
I'd focus on the battery connections.
May 19, 2010 | Motorola Mobility Moto Q
My phone will not turn on
Hot sync the phone, clean the battery contacts (touch of alcohol on a q-tip), and try a soft restart...which is simply pulling and reinstalling the battery.
If it does it again, you may have a corrupt application. Hot sync the phone, do a hard restart (pull battery, reinstall battery, hold down power button until black bar crosses bottom of screen, select "yes" to reformat, and re-sync the phone to reinstall the software and data.
If it continues to be a problem, you can try replacing the battery or removing user-installed applications one-by-one to see if the problem clears...but the problem is most likely an unstable phone.
Sep 11, 2009 | Palm Treo 500 Centro
Nokia 5800 won't turn on
"my phone just says NOKIA and its blank white- no matter what you press, no change even though it is fully charged what to do??? pleeeese help "
I had the same problem, I took off the memory card and de sim card, i turned the phone on... and then off... and then I had put back the two cards, and i turned it on again... I worked
Feb 11, 2009 | Nokia 5800 XpressMusic Smartphone
Power cycling
I had the same problem. Actually, it began about thirty minutes prior to me posting this solution. Of course this may not work for you but it worked for me.
My problem began after I plugged my phone into my computer. I hadn't done anything to it. I went to turn it on and it entered the seemingly endless restart cycle. It likely had something to do with being plugged into my computer. I toyed with the battery and whatnot but to no avail. Eventually, I took the battery out and put the phone on AC power instead. It made the cycle shorter for some reason but did not solve it.
I then put the battery back and put the phone on AC power. I powered on the phone and it went to the initial loading screen. After that, it went to the charging screen which was weird because my phone should have been at 100%. From there, it proceeded to power on competely. End of problem.
I will note that I also had my USB sync cable plugged into my phone although it was not plugged into the computer. The charger was plugged into the adapter port on the sync cable but I suspect you'll get the same result without it.
Sep 21, 2008 | Samsung SCH-a930 Cellular Phone
Ive tried the solutions posted here all ready
This is not much of a solution but I pulled my battery out then put in back in. Once I powered on the unit, I get the Creative logo, it updates the library and I'm back up. BUT, then I tried to sync again, and again, and again. Same result each time. I also found that it will not sync past 50% of anything I try, 1 song, 1 album, 100 songs or 100 albums. It always freezes and I can't power off.
Dec 17, 2006 | Creative Labs Zen MicroPhoto MP3 Player
Palm Treo 500 Centro Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
