Question about RCA P60828 TV
27f400t I HAVE A PROBLEM WITH THE TV TURNING ON AND OFF BY ITSELF. I CAN UNPLUG IT AN PLUG IT BACK IN AND THE TV WITHIN A FEW MINUTES WILL SHUT OFF AND A FEW SECONDS TURN BACK ON AND THEN OFF AGAIN....
  • truckers_wom Mar 30, 2009
    The same if we plug it in it goes on and off on its own and the controlles don't do anything
Replace the 6 tact switches on the front of TV. I have encounter many of these models with this problem and replacement of these switches does the trick
Posted on Oct 13, 2009
  • 905 Answers
This is the EPROM chip or a controling circut on the board
Posted on Oct 09, 2008
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
Sep 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
May 23, 2009 | Panasonic Viera TH-42PX80U Plasma TV
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zenith 27" TV
I sorry to say I think you have a component failing that is related to heat. 15 years is a long time and if the TV was used in hpot conditions over the years it may well be the proble, or it's just old.
Sep 23, 2008 | Zenith C27A24T 27" TV
TV wont stay on
TRY THESE STEPS
>Check the buttons on the TV make sure they are clean and not sticking.
>Check the Remote Control buttons and see if they are sticking
>Clean the Face of the infer Red lens to the remote and the TV...
clean them with a small rag or paper towel (Do Not USE Abrasives to clean any part of your Electronics)
>Check the plug for any defects
>Reset your tv back to it,s factory settings
>And if any thing locate your user manual and find the 1-800 number
Aug 27, 2008 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
TV turns off by itself & won't turn back on til unplugged, then plugged back in
Well, first your model number is the 42 inch, but I digress...
I had a similar problem with a Viewsonic 27 inch, with the blinking power light on a failed power-up. It turned out that replacing the power transformer was the ticket. However, as I have the 50 inch Panasonic plasma, I know that the transformer is built into the set itself. I'd still suggest that this is what needs replacing though, as this is different from a set being on but having no picture.
Apr 18, 2008 | Panasonic TH-50PX75U Plasma HDTV
TV turning on and off
Try reset.Unplug AC cord for a few minutes, longer,if doesn't work.plug back in--try again.
Oct 09, 2007 | RCA 32V420T 32" TV
RCA P60828 TV Logo
363 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
