Question about Pinnacle Computers & Internet
Cannot find the serial key to the movie box studio instal disc
    Scholar:
  • 54 Answers
Hi yellowbret,
Sometimes the serial number is part of lager alpha/numeric character string. When tried to install and it asked you for the serial, look to see how many characters you can type into each text field. Its usually limited to amount of characters in the number. Once you have that information see if any of the numbers you can find match the total character input for the requested serial number. There is a series of numbers that are etched on the back center ring of most cd's, however, I'm not sure what they represent( I bet someone on here knows the answer to that). You may need a magnifying glass to read them. There several on-line serial key finder utilities you can explore. I hoped this helped.
Thank you for using FixYa.com
Sincerely, cyyyd7
Posted on Oct 09, 2008
I cant find the serial number to my canon dc100 camcorder.its not on my instruction book or on the cam.theres a number under the battery but thats not it.im trying to open the coral dvd movie maker disc...
the coral dvd movie maker program is looking for its serial number
the serial number of the camera will not help you.
also called the product key or serial key.
it should be in its manual, box, or dvd case.
the serial keys are long like a windows OS key
example 4RT2-8XPT-89HT-PTR9-UCT0
it should be on a special sticker in the front or back of the manual,
on the back/side of the box, or on the dvd case that the dvd is in.
sometimes its on a seperate card.
Mar 11, 2011 | Cameras
I can not play my dvd on sony dvd player i get message canot play.i have a sony dvd recorder in which my laproscopic surgeries are recorded.if i play my unedited dvd on player it runs or plays very well...
My guess is the Pinnacle software isn't writing correctly. Read this from the Pinnacle support site.
Use this FAQ to troubleshoot any problems where Studio is failing during the process of burning the DVD.
  1. INSTALL THE LASTEST PATCH:
If you have Studio version 12, download the latest version here.
If you have Studio version 11, download the latest version here.
Note: Studio 11 patches will only patch a previous install of Studio 11.
If you have an older version of Studio (Studio 9, 10, or 11 etc), it is advised for you to update to the current Studio software. The current version is Studio 12. Click Here to go to the Studio 12 Upgrade page.
How to download and install a patch:
  • When downloading the patch make a note of where it is being saved to. We recommend saving the patch to the desktop.
  • Before installing the patch, make sure that you do not have any other programs running. Studio must not be running.
  • Once it is fully downloaded, double-click on the patch to begin the installation.
  • Follow any on-screen prompts to complete the installation. Reboot the computer after applying the patch.
  1. MAKE DISC SETTING, SAFE MODE BURN OPTION: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Safe Mode: create disc content and then burn" by clicking on the radio button in front of the setting and then click OK. While troubleshooting this problem, always use this setting.
  1. RESTART STUDIO: Shut down Studio, then relaunch it. Try to create the DVD again using the safe mode setting above.
  1. RESTART THE COMPUTER: Try opening the door of the DVD burner. If it won't open, then shut down Studio, then restart the computer. Launch Studio and try to create the DVD again using the safe mode setting.
  1. MEDIA:
BLANK MEDIA IN THE DRIVE: Make sure that there is a blank, write-once media or rewriteable media in the DVD burner.
TYPE OF DVD: Make sure that your DVD burner supports the media you use. As for any problem with burning a DVD, we recommend customer use rewriteable media to reduce the number of wasted DVDs when they have to troubleshoot a failure while burning DVDs. In this case, if you have only used rewriteable media, (RW) we would also recommend trying to use a write once (-/+ R) DVD and erasing the RW media.
BRAND OF DVD: Pinnacle recommends using a name brand of DVD, i.e. Sony, Apple, Memorex, etc. Also we recommend trying a DVD from a different manufacturer to see if the problem is related to the brand of DVD that is being used.
NOTE: Check with the following site to find information on the media being used.
http://www.videohelp.com/dvdmedia
  1. LOWER THE WRITE SPEED: In the Make Disc settings try lowering the Write Speed to the lowest possible setting.
  1. GET THE LATEST FIRMWARE: Ensure that the DVD burner being used has the latest firmware update from the burner manufacturer.
  1. CHECK DISC SPEED: Make sure that the disc media speed (printed on the media or on the media box) is compatible with the DVD burner. Some burners may not work with media that has a higher maximum supported burn speed. For example, if the burner being used supports 4x disc media, do not use 16x disc media.
  1. DELETE AUXILIARY FILES: Try deleting the Auxiliary Files for the current project. To do this, go to File -> Delete Auxiliary Files and select "Delete auxiliary files for current project." Press OK and try to re-render and burn the project.
  1. ALWAYS RE-ENCODE: Go to the Make Disc settings and check the box called "Always re-encode entire movie".
  1. SAFE MODE: Try burning with the safe mode option selected. To do this, go to the Make Disc settings. In the Burn options are select the option called: "Safe mode: create disc content and then burn.". This step does not apply if you are using Studio 12 since this is the default burn method.
  1. CREATE A DISC IMAGE: In Studio, click on Setup -> Make Disc. Under the box marked Burn Options, select "Create disc content but don't burn" by clicking on the radio button in front of the setting and then click OK. Then click the Create disc button in the Make Movie section to begin the image creation process.
    If the image is not created, it is likely that the problem is a Render problem rather than a burn problem. Click Here to see the FAQ on Render problems.
    If the disc image file is created successfully, burn the disc from the new disc image by selecting "Burn from previously created disc content" in Burn Options.
    NOTE: When troubleshooting all burn or playback issues, it is recommended to use rewritable media to avoid wasting discs.
Nov 04, 2010 | Sony DVP-NS530 DVD Player
Export:error:real time c:\users\owner\appdata\local\microsfolder\render\my movie 848e009f\alternate\render\my movie 848e009f\dvd\studiosequence\temp' Help - what does this mean? What should I do?
Hi and Welcome,
If you are experiencing Export Errors using Studio, the following FAQ should help:
1. UPDATE TO THE LATEST PATCH:
Click here for the latest Studio 12 patch
There is no patch available at this time for Studio 14
2. ENSURE BACKGROUND RENDERING COMPLETES:
Allow the green bars that appear over clips that have had filters, transitions or other effects added to complete before going to the Make Movie stage.
3. ALWAYS REINCODE ENTIRE MOVIE
If after installing the latest version of Studio, the Export Error persists and you are attempting to create a DVD, then in Studio click on the Setup pull-down menu and select Make Disc. On the top portion of the Make Disc tab make sure there is a check in the box for the setting "Always re-encode entire movie", then click the OK button. Create the DVD again.
4. DELETE AUXILIARY FILES
Delete the auxiliary files before rendering. To do this, go to File >> Delete Auxiliary Files. This will bring up a window to chose which auxiliary files will be deleted. Select the option to delete the files for the current project. Once this is done, try to output the project.
Oct 12, 2010 | Pinnacle Studio Ultimate 12 for PC
Corel video studio pro x3 serial key
Your complete video-editing workflow solution—from shoot to share · Start with studio-quality templates, real-time effects and royalty-free music
· Edit and render faster with GPU acceleration and multi-core Intel® CPU support
· Author menus and burn to CD, DVD or Blu-ray
· Navigate, assemble clips and edit faster with the redesigned interface
· Share on YouTube™, Vimeo®, Facebook®, DVD, Blu-ray Disc™, iPod® and more
Corel VideoStudio Pro X3 is your end-to-end video production package. Now twice as fast, it delivers express and advanced editing modes, studio-quality templates from RevoStock™, improved filters, titles, and powerful real-time effects from NewBlue®. Share your movies with HD and Blu-ray authoring, and send directly to YouTube, Vimeo and Facebook—all from one complete package.
Jul 03, 2010 | Computers & Internet
I have a legal copy of 321 studios and need to install it on another computer. However the process requires, internet connection (to a defunct company), Phone call (to a defunct co.) or orginal computer...
If you have legal copy then you can find serial number for registered it.
You can get it from disk cover or disk surface.
Then you can enter that serial number when you install software it ask for serial key so it registered.
But if you are unable to get serial key then drop an email to this software manufacturer web sites supports or login with id and password on that web sites then you can get serial key for register it without internet.
Let me know if you need further assistance.
Thanks for using FixYa.
May 11, 2010 | 321studios 321 Studios DVD X Copy (Backup,...
How to get serial number
Good effort.. you wont get cracks or serials here. If you have bought a serial, then just email Sony and it will be resent to you.
Jan 25, 2009 | Sony Acid Music Studio 7 for PC...
Serial key #
If you did register a serial number with Pinnacle Studio online, they should be able to retrieve it for you. If your box doesn't have a serial number anywhere in it (usually in the manual or on the CD or DVD sleeve) then your copy might be pirated.
Feb 25, 2008 | Computers & Internet
Computers & Internet Logo
142 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
