If you mean the carafe, you're out of luck getting the original. A company called focus electrics handles replacement parts for this brand. Their
parts page for this model lists nothing at all.
If you need a new carafe because yours is leaking, join the
club. This seems to be a pretty common problem. You can try tightening the screws
holding the gasket to the bottom.
If you don't mind losing the one-hand dispensing feature, you might try a universal replacement carafe which may fit. These are usually found with the coffeemakers at retail stores. Or you can buy a new coffeemaker. Sometimes the difference in price between parts and a new machine is pretty small.
Good luck, and thanks for using Fixya!
Displays "not ready" for a long time and then about 30 minutes later it is ready
same exact problem. Just keeps reading "not ready" i've opened it, closed it. emptied it, filled it. unplugged it and of course replugged it. nothing. less than a year old too....
have opened and closed numerous times and cleaned needles as well, still
only reads not ready
We just bought ours and are following priming instructions. It keeps displaying NOT READY. Called Customer Service but no technicians available in the evening. Waiting for call back tomorrow with "reset" instructions.
Same problem. I can hear the water trying to heat but NOT as loudly as usual. I think somehow the heating element is no longer working right. Never says "ready".
Coffee will not brew no matter which button is pushed. There is adequate water, I use a new pod and the electrical connection is good. The ready light comes on but after I close the lid the light says "not ready" and only a drop of coffer emits.
I moved my coffee pot to clean, spilled some of the water, and I think it may have done something to the heating element. Either way, I'm taking it back and demanding a new one.
I have bought this 3 times and each time the "not ready" thing happens. It is like clockwork. I admit that it seems to happen right at the same time it recommends a cleaning. By the time I go to do this, it is too late and inoperable.
That open/close thing doesn't work.
