Question about HP DeskJet 812c InkJet Printer
Lines through pictures
When I print pictures, there are white lines through them, like the cartridge is missing.
  • 905 Answers
Could be low on ink , could be clogged , could be bad connection of the wire strip or broken wire in wire strip
Posted on Oct 09, 2008
Vertical white lines on page after printing
There will be something covering a small patch of the laser mirror. Find the laser mirror inside the machine (Normally above where the cartridge sits) and wipe this with a clean cloth. Other than taking the cartridge out there is no dissassembly required.
Dec 25, 2012 | Canon LBP 1120 Laser Printer
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Printed output has white lines....
white lines mean ur cartridge working not good change cartridge or clean incotter (printers part )
Apr 07, 2010 | HP DeskJet D1460 InkJet Printer
Lines running through pictures when printing color and/or black.
Hello sir;you missed one place that is ink cell.
Aug 28, 2009 | Kodak ESP 5 Printer
White lines and "missing ink" on printing text & graphics
you have a defective or near empty toner cartridge. Try shaking it side to side
Jun 11, 2009 | HP LaserJet 1100 Printer
While printing photos my printer has white vertical lines
Sounds like you need to re-align the print cartridge . The reason the text comes out ok is probably because it is only using the black cartridge for text. The color cartridge is the one that's out of alignment. You may have some sort of Cannon utility running in the task bar that will allow you to easily allign the print cartridges. If not, go to the main "Printers and Faxes" window, RIGHT-click on the printer and select "Properties". You should be able to find a button in the properties that's labeled something like re-align print cartridges. It will print out a series of test pages and ask you to select the set of lines that looks the straightest and type it in. It's a good idea to do this every time you replace a cartrige. Hope this helps, If I was able to FixYa, please remember to rate me. Thanks.
Feb 22, 2009 | Canon MultiPASS F50 All-In-One InkJet...
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Nov 10, 2007 | Lexmark X5470 All-In-One InkJet Printer
HP DeskJet 812c InkJet Printer Logo
76 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
