Question about Sony XR-C5100 CD Changer
Car Radio Radio cuts out. Also, how do you connect the CD Player?
  • Hohepa Oct 09, 2008
    Sony MD/CD Changer Control. XR-C5100
    Super Fast and Efficient!
    Sergeant:
    Champion:
  • 334 Answers
Need cable for it hope it has oen on radio make sure u have great ground on player itself ok to car chisis thx nick
Posted on Oct 09, 2008
    Brigadier General:
  • 3,614 Answers
What is the exact model / maker, and also the maker of your cd player..
tnx.
My radio harness was cut and tring to install cd
okay you will need to hard wire it in the vehicle. so i will need to know what year make and model car you have?
Jan 31, 2010 | Clarion DXZ645MP CD Player
Car radio/cd player cuts off radio will not play cd will not play ,hit the power button and will come back on some times it wil not. its seems like there is static sound when the music does not play on the...
Hello pinkperry,
It sounds like the wiring between the cdplayer and the dash has come loose. When the wires are not making proper connections some of the speakers or functions of the radio cut on and off.
This is just my first thought and the easiest thing to fix. You will have to remove the cd player from the dash. After which you will want to check the wiring. Chances are your cd player has a harness if it's an aftermarket cd player installed in your car. If it does there will be two sets of wires to double check.
Just make sure all the wires are securely twisted together (the sets of wires) and taped up with electrical tape.
Try that and post back if you have any further questions. Thank you for choosing Fixya!
Aug 25, 2009 | Car Audio & Video
How do i connect the wires to put in new cd player in 95 aurora
ok you nee d to go to walmart or your closest car audio center and purchase the wiring kit for your year model vehicle the kit will have the plugs to plug into your factory harness do not cut your wires these plugs will have the wires labeled wire them to your new radio and it should plug in and play you may also need to aquire a face kit for mountring the sterio
Mar 01, 2009 | Dual XD-7500 CD Player
Cuttinng out
Does it cut out when you are listening to the tuner as well as the cd player? If so, you have a bad connection somewhere. Sometimes the solder joints inside the radio can be cracked and will cut out when you hit bumps. May be a wire that is a little loose. Check all the wiring.
If it only cuts out when you are listening to the CD player, you may need the lens cleaned or the laser replaced. Sometimes the cd player cuts out because the unit has too much wiggle room and it bounces a little when you hit a bump causing the cd to skip or cut out. and there is always the dirty CD. Try cleaning the CD's with windex and a soft cloth like a bath towel. It works great for me and is cheap. Fingerprints can and will cause a cd player to skip.
Jun 07, 2008 | Pioneer DEH-P6800MP CD Player
Wiring diagram of audio for EF falcon
Since you did not list a specific vehicle make or model.
I usually find all of the wiring diagrams HERE.
Best of Luck.
Please RATE my solution BELOW.
Nov 24, 2007 | Kenwood KDC-MP208 Car CD/ MP3 Player
CD player that doesn't play
I had the same problem.
I cut the orange wire which went into the black connecter block
and WOW I had sound...
brilliant
thanks a lot
Andy - North Yorkshire, England
Oct 11, 2007 | Panasonic CQ-C1303U CD Player
Bad performance
You will need to double check your installation my friend, such as make sure all of the power connections are good. If that does not correct the problem, most likely you have a problem in the radio and these days you can get a good Sony or Pioneer in dash with a cd for around a hundred bucks or so. Good Luck
Jun 05, 2007 | Pyle PLCD55 CD Player
Jensen MP7610 power cuts off frequently from time to time
i have a eclipse that would cut power to the cd player when ever it wanted. it turned out that the yellow memory wire had a bad spot in it. i cut a chunk out and then made a fresh connection from car to cd player and has worked great ever since! give it a try.
Nov 14, 2006 | Jensen MP7610 CD Player
Car Audio & Video Logo
111 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
