Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
Someone please help us to figure out why our chest freezer/frigidaire 5 cu ft small chest today , this morning started making a loud fan noise like it needed WD40 but then when we turned the temp dial down to off and back on it stopped then slowly started again. Then within moments I turned it to 2 on the dial and the fan stopped but a couple hours later no noise and it wont come back on after being shut off completely?
We took all of our food out of it and are upset completely , it was bought at LOWES back in 2002 and is practically new hardly used. Always been on and on temp #6 to 7!
HELP!
    President:
  • 1,462 Answers
At 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Posted on Oct 09, 2008
Cubic feet for Frigidaire Chest Freezer MFC13M4FW3
Good Morning, thank you for your question! This particular unit is a 12-13 cubic foot freezer. If you have further questions, please do not hesitate to reconnect.
Jul 20, 2013 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire 20 cu. ft. / 566 liter Chest Freezer FFC20C4A manual
Contact Frigidaire on www.frigidaire.com for a downloadable copy of the manual. Or you can reach their center at 1-888-203-1389.
Dec 26, 2012 | Frigidaire 20 cu. ft. / 566 liter Chest...
Just got a used 5.0 frigidaire chest freezer and noticed that it is starting to frost at the top but water is starting to pool at the bottom. any help would be appreciated
Good day,
The interior walls should frost evenly. If you only get a partial frosting pattern then either you have a refrigerant leak or a restriction in the refrigerant lines.
Either problem would be considered a terminal failure in a chest freezer.
Mar 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
We have a 21 cu ft 2009 chest freezer. It is not
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 08, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
After being unplugged for one year, my Frigidaire 5 cu. ft. / 142 liter Chest Freezer FFC05M0A turns on, but does not get cold. What is the problem?
It's probable that you've lost refrigerant in the cooling system. Unfortunately, leaks in those systems can be hard to find so check your warranty to see if the labor is still covered.
Oct 26, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire Chest Freezer Door Insulation smells like fish
might sound stupid but take the cover off the compressor electrics and make sure no plastic is overheating.
Oct 08, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Freezer not working
compressor is faulty. clicking noise you hear is the overload for the compressor. not worth repair and not diy
Mar 18, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Open Questions:
See all Frigidaire 13.7 cu. ft. / 388 liter Upright Questions
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D Logo
280 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
