Question about Toshiba 27A62 27" TV
S-video I am trying to connect my laptop to the tv to play the laptop on the tv with an s-video cable. How do I do this?
  • 905 Answers
If your laptop has s-video out then just plug it in to the tv's s-video input , otherwise its a RCA jack for the video ouput( yellow colored jack )
Posted on Oct 09, 2008
What kind of cord do I need to connect my laptop so Netflix Movies can play on our T.V.?
Hi Candice,
First, without the model of your TV *and* laptop, no one will be able to give more than general information. It is much better to provide too much info than not enough - to get questions answered quickly here. With that said..
The short answer is that you need a cable that will connect to your note book (most likely either Video [yellow], S-Video, VGA, DVI, Display Port or HDMI) and the TV (most likely RF, Video, S-Video, PC / VGA, HDMI or RGB) Only the HDMI cable will provide sound with video. The others will require either an audio connection from the laptop (probably via a 3.5mm stereo headphone output jack) to the TV (most likely standard "RCA" jacks [red & white] - or settling for the laptop speakers or external amplified speakers plugged into the headphone jack.
If you are unable to locate a cable that has the connector supported by the laptop with a connector offered on the TV, it is likely because it is not possible to connect the two (HDMI to video, etc.) with only a cable. Additional hardware (probably expensive if available) will be needed to up or down convert & split audio to make it compatible.
Take a photo of the jacks offered by your laptop and those on your TV to a respected TV / Audio store / department for additional assistance. Some Radio Shack store employees are very good - and some are just plain horrible. Save your receipts in case it doesn't work to your liking.
Keep in mind that a $50 Roku box will stream Netflix (and a whole lot more) to most TV's "right out of the box" - or by buying $10 HDMI cable online to connect an HDTV. Don't spend 20, 30 or more dollars on an HDMI cable unless you want to pay too much!
I hope this helps and good luck!
Oct 22, 2013 | Computers & Internet
How can i connect my macbook pro to my LG 50PJ350 to play movies?
I would try an s-video connection from computer to tv, it just might bypass all that copy right stuff that may be giving you problems
Jul 28, 2013 | LG 50PJ350 50 HDTVReady Plasma TV
Hi I'm trying to connect my laptop to play photographs through the TV screen using windows XP. No success at the moment. How do I connect up please? And can i get a manual for the TV anywhere...
For making the physical connection between PC and TV first we need video cable.
PC has S-Video port that should be connect to the S-Video input of your TV using S-Video cable.
Connect the computer to the TV using VGA ports or via the DVI to HDMI cable. These Macs need Adapter for a VGA cable.
RCA for audio, connect RCA to your PC and red and white colored sockets of RCA cable to TV (left audio-white, right audio-red).
In your PC open the Display Settings and activate output to the TV screen.
In your TV open the menu from that open the External inputs. And change the video to HDMI depends on the connection.
You can also change the screen resolution of your TV using the Personalize and Display Settings options in your Control Panel on PC.
After giving the connections you can watch the movies and everything is running on laptop on TV.
Jun 07, 2011 | Televison & Video
How can I connect to my TV to play DVDs? I have a ACER travelmate 6293.
ur laptop has a S-video/TV-out (NTSC/PAL) port, which can be used 2 connect 2 a compatible TV or a AV reciver. try using a svideo cable
Mar 02, 2010 | Acer Computers & Internet
How do I get the "Watch Instantly" feature to play on my TV? Do I have to have my laptop hooked up to it while the movie is playing? Also, is there a way to save these movies to my Tivo so that I can watch...
Sounds like a netfilx service your using? Yes the laptop will need to be connected to the TV, Now if you want to save to pvr I would suggest you get a ROKU box www.roku.com there about 100 bucks wit hthis you can save to a tivo and more!
I hope this helps please do click the accept button for my efforts/
Dec 29, 2009 | Televison & Video
Connect Laptop to TV
It depends on what kind of TV you have. If you have a flat-panel LCD or plasma TV, it may have a VGA connection already installed. If that is the case, all you need is a standard VGA cable to connect from your notebook to your TV.
If you have a TV without a VGA connection you will need a scan converter to convert your signal from VGA to RCA or composite video signal. These can be purchased online or from electronics stores like Radio Shack. You plug your VGA connection from the computer to the scan converter, then RCA or composite video cables from the converter to the TV.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | HP Compaq 8510p Notebook
Connecting laptop to lcd
You may need to use the S-video cable for video. Make sure video mirroring is disabled on the powerbook. Also, make the external monitor the primary display by dragging the menu bar to it in Displays preferences (Mac OS X) or the Monitors control panel (Mac OS 8 and 9).
Mar 14, 2009 | LG 32LG30 32 in. LCD HDTV
Laptop outputs graphics but not video to TV
try using the 640 by 480 resolution. If no go, update the video driver on the laptop. Try different cables to connect the system to the TV.
Jan 31, 2009 | Computers & Internet
DVD from laptop to computer
MaionP:
you need to connect your TV to your laptop with the audio cable as well. A simple S video cable will only gives you video. You can buy a simply audio video cable and use the audio output from your laptop to your TV and keep on using the S video for video.
Or you can use simple external laptop speakers to gives you sound with your TV output.
Hope that helped!
Dec 09, 2007 | Computers & Internet
JVC LT-42DA8BJ
unable to get laptop image on samsung lcd tv. Can anybody post some clue please
Oct 27, 2007 | Televison & Video
Toshiba 27A62 27" TV Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
