Question about RCA HD52W58 52" TV
Powers on. green light flashes then turns back off.
I can't turn the tv on. The manual says a lamp needs replacing. The manual does not reflect correctly the rear housing of the tv. I can't find this lamp.
  • 4 more comments
  • greg431207 Oct 09, 2008
    Reply to Abrsvcs posting 10/09/08. The model number is HD52W58 serial number E393C5026.
    Abrsvcs, the tv does have the red,green,blue lamps aimed toward a big mirror behind the screen. I have torn the tv apart trying to find this fourth lamp to no avail. I am 100% percent sure that the tv is a DLP model. Your comment suggests that there may be a different problem/solution. However, as have searched for a replacement bulb at the RCA website, they respond with a picture of the lamp in its cartridge or lamp only with prices from different vendors. I don't know which direction go in at this point.
  • kylaabbe2007 Oct 29, 2008
    the tv turns on then i push the power button but turns off right away.
  • legend426 Oct 30, 2008
    I have the same problem! when I try to turn the TV on the green light comes on then turns off, maybe a second later it'll turn back on by itself (green light) then turn back off.. Tv's probably only about 4 years old! Whats the problem?????
  • Need TV Now Feb 03, 2009
    This is so freaky. I have the exact problem. It doesn't seem as if there's anyone out here to help us. I too had this television for at least four years. The power switch turns on and turns right off.
  • katrina sandoval Mar 18, 2009
    tv turned off yesterday and will not turn on the power light blinks about 9 times i have the rca HD52w58 52" tv
  • 3 Answers
For troubleshooting your lamp, use the following lamp troubleshooting wizard here:
If it turns out you need a lamp, you can follow the simple instructions available here for just about any make and model, including your RCA. The RCA website is useless and they never have parts in stock.
Posted on Jan 28, 2009
  • 4,234 Answers
Please post the model number of your set. The category you have placed this question under is for a CRT based set that has no lamp. I should be able to help once I get the model number.
Posted on Oct 09, 2008
  • ABRsvcs Oct 09, 2008
    If you see the red/green/blue CRTs, there are no other lamps. You DO NOT have a DLP machine. It is CRT based. What light is flashing and how many times? Is there any sound at all?
DLP powers down after 1 minute; no sound or audio
Jul 07, 2013 | Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
The screen went blank and green light started flashing. Turned off the TV and let it cool. Turned it back on, getting sound but no picture. Red light is on, after about 15 seconds the green light blinks...
Since you say that there is sound but no picture, the first thing I would check would be the status of the lamp. I believe that the lamp has been shattered or the filament is blown. Please verify this and let me know
Feb 25, 2011 | Toshiba 52HM95 52" HDTV Projection...
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Suddenly turned off without warning Sony KDS-50A2000
All you need is to open the back cover of the television and check on for dry soldering at the power stage of the printed circuit board, also check for bulged capacitors, if found replace with same rating of voltages , but if otherwise Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
Hope this helout, Good luck....
Jul 11, 2010 | Sony KDS-50A2000 50" HDTV
Powers off with a blinking standby light for 45 blinks
Yes, its clear symptoms of weak lamp that is going to end of its working life, soon tv will show you lamp light.
Replace lamp to solve the issue, lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
May 25, 2010 | Sony KDFE50A10 50" HDTV
I have a Sony Wega KDF-50E2000 that doesn't turn on. The green light blinks for a minute or so and then the red "timed out" light blinks continuously. Yesterday, the TV turned itself off with the green...
Did you replaced lamp in TV recently?
I think TV needs new lamp as existing is either broken or dead.
Lamp replacement procedure would be mentioned in user manual or let me know to provide you more info.
Sep 16, 2009 | Sony KDF-50E2000 50" HDTV
Lost picture and sound
You likely have a bad lamp. The symptom you describe matches a weak or old lamp. When you first turn on the TV, the lamp is cold and doesn't draw much power. But old lamps usually have clouded reflectors, so the reflector doesn't reflect the light, it converts it into heat. The bulb overheats, draws more current than allowed, the TV "recycles", green light flashing and then the process starts over. Replace the lamp, use and original Sony lamp as the aftermarket lamps are known troublemakers. Please be sure to rate this solution. Thanks!
Nov 09, 2008 | Sony KDF-42WE655 Television
RCA HD52W58 52" TV Logo
304 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
