I have a motherboard that will not POST. I am not sure the reason, but I suspect the BIOS.
  • 171 Answers
Does the motherboard power -on, Is the CPU installed correctly and is it rated for the board? Is the memory seated properly? I know that these are dumb questions, but they must be asked.
What is the Brand ad model of the motherboard?
Posted on Oct 09, 2008
I have a msi board that is not beeping during bios,what could be the problem ?T
If the motherboard is not posting there could be something wrong with your bios. OR, if you have a problem with a peripheral that might also cause the mo bo to not boot up - in the latter case remove all items except the memory and attempt to post. If it does add items one by one until you come across the epripheral that will not allow the mo bo to boot.
If no post with all items removed then the mo bo is definitely suspect. U can try using a new bios chip but that is not a guarantee that it will work.
Apr 10, 2015 | MSI Computers & Internet
No diaplay intel GVSR 845 POST Card error code E9
The Intel D845GVSR Motherboard manual reports the Error code as - "Entering Bios Setup"
If you didn't have display, you wouldn't see the error, this means the monitor has picked up a generic driver and is working. Fo some reason the system is trying to enter the BIOS.
Read the Manual on how to clear CMOS, or after touching metal you can carefully remove the battery from the motherboard for 5 mins. If after you clear CMOS and the board still reports this error, go to the Intel website and download the latest BIOS update,( P20 ).
Make sure you read and follow the instructions on flashing a BIOS update.
This board is very outdated, and even posted on the intel website that intel has -
Notice : End of Interactive Support
Mar 31, 2013 | Intel D845GVSR Motherboard
How to acsess the boot device menu at post on abit il8 motherboard
.Abit did not add the BIOS post to the manual.
Watch the BIOS post, most all motherboards have the hot-key menu at BIOS post.
If for some reason the hot-key is not reported on BIOS post, then you hit the DELETE key and enter the BIOS, Advanced BIOS Features Setup Menu and set what hardware you want to boot first, under Hard Disk Boot Priority, set First Boot Device
Mar 31, 2013 | Abit IL8 Motherboard
I Am Not Found the windows xp Sound drivers
Hi, Thanks for using fixya.
Check the bios make sure it is enabled.
F-key should be listed for bios setup at first splash screen (name of motherboard) When you are in the bios setup click on CMOS Setup tab at the top. Then look at at via ac97 make sure it is enabled. If it is search your favorite search engine for AC97 drivers.
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
Feb 20, 2011 | Mercury P4VM800M7 Motherboard
ASUS P4P800-SE (I have 2 identical boards) 3.0 GHz HT processor -- tested & good (actually have 2 spares) 2.5 GB RAM -- all tested & good 2 different power supplies tested (350W - seems to work...
I don't understand... are you able to POST or not?
Are you sure that both DVD drives that are on the secondary IDE channel are configured as MASTER and SLAVE by using the pins on the back of the drives?
Mar 31, 2010 | ASUS P4P800 SE (890552603657) Motherboard
Dead PC, Pheonix Award Bios post code 2A, ASUS A7V400-MX SE Mothe
There is 3 reason for 2a error
Ram power supply mosfet open or short
bios programme currupt
Feb 02, 2009 | MSI Galaxy KT400 (MS-6596-20B) Motherboard
Ram not working with motherboard
Hi
Check if your motherboard only supports only dual channel interleaved memory from the manual because it might be the main issue of your problem. Also DO NOT plug in the 512 MB ram you have over there. If it is ok to have one Slot empty then there should be no reason why it should not POST properly. Before jumping to conclusions that the RAM is faulty. Make sure that you REMOVE any overclocking you might have on the system. Some RAM won't post wihen the CPU clock and multiplier are not standard. Also it could help if you load FAIL SAFE settings in the BIOS until you determine the proper cause of the problem.
Hope that this helps :) (please rate thanks)
Jan 07, 2009 | Intel D865GBF Motherboard
PC CHIP Motherboard
Now by PC chips do u mean CPUs? because if so then yes your motherboard is dead but im not sure if it would be BIOS related. There should be a battery somewhere, one like a wristwatch but bigger and flatter on the motherboard, look for it and replace it and test if it works, otherwise it is most likely your motherboard is dead and you need a new one. There is a way of fixing the BIOS if that is the problem. Its called Force Flashing BIOS. I Don't know too much about this but apparently its not hard. Google It and see what you come up with
Hope This Helps
Oct 22, 2008 | IBM ThinkPad T20 2647 Notebook
During the POST
maybe your board chip and bios are not supporting any of those plug into your computer. the reason why hangs on POST because it override the maximum limit presented on bios and chipset. Try Updating your bios and chipset. Warning! it must be a exact detail number and serial of updates you must use.
It is very risky but I try it with my computer. Now I can use large capacity of RAM, Hardisk and even PCI 2.0 plug-ins in computer with only 133MHz.
Jun 26, 2008 | VIA GA-7VAX (MB-GA-7VAX) Motherboard
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
