Pioneer Elite Pro 530HD (Rear Projection TV) Power Standby Indicator Light Flashing TV will not turn on.
I was seeing what appeared to be a cobweb behind the lend of this Pioneer projection TV.  I started to unscrew the back to see if I can remove / clean this.  As I unscrewed the back the TV power went out.  I noticed after I removed it that there was a spring loaded switch behind the back cover to automatically shut off power when the back cover is removed.
I vacuumed all the dust off inside of the cabinet being careful not to bump anything. Then I started installing the back on and proceeded to turn the TV on.  However, the TV power does not go on.  The Power Standby Indicator Light flashes at a steady pace.  Any advice would be greatly appreciated.
  • 1 more comment
  • JohnCataldi Oct 23, 2008
    I have the same issue also and didn't do anything, trying to seek help.
  • rrchebultz Nov 09, 2008
    I have the same problem....does anyone know of a fix!!!!
  • sheitchler Apr 20, 2009
    I took the back off to "clean" as well and now I have the same problem. What is the solution???
5 Suggested Answers
SOURCE: cleaning JVC rear projection screen (behind cover)
You will have to do some dissassembling of the cabinet to remove the screen and bezel assembly. If you are will to do this I can give you the directions.
Posted on May 11, 2008
MrBob84
  • 90 Answers
SOURCE: Pioneer Elite Pro 710HD Rear-Projection Television
no reset sequence. usually when the protection kicks in without any warning, it's the convergence ICs needing replacement.
Mr Bob
www.imageperfection.com
Posted on Nov 12, 2008
SOURCE: pioneer elite pro-530hd tv---no picture at all!
I have a 532nd 53 that shuts off and red stand by lite comes on in the back. If you wait awhile and unplug it and plug it back in it will come on again and then shut off after an hour or two
Posted on Oct 26, 2009
hardrocko
  • 1476 Answers
SOURCE: I can see old twisted cobwebs, now tangled,
xxlracer,
See my tip at http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv for help.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Jun 14, 2011
NEED OPERATING MANUAL FOR PIONEER ELITE PRO 530 HD TV
both may be a little hard to find anymore, the main problem is dead set and that is bad soldering all over the giant power supply board this set uses.
Sep 02, 2012 | Pioneer PRO-530HD 53" Rear Projection...
What's your problem?Pioneer PRO-530HD 53 in. Rear Projection Television flashing red standby light
This and a few other models like it have one real common issue:
they develop from age and heat bad solder connections all over the power board (rather large board).
My experience with them is the fix usually is remove rear cover and follow power cord to power board (a lot of plugs to mark) and remove that board----then solder every single connection on the board which by the way has some special fuses on it.
Jun 14, 2012 | Pioneer PRO-530HD 53" Rear Projection...
Have a Pioneer pro elite 730hdi. When you try to turn it on (main power, not standby), the tv cycles from the red (standby) light with the normal click to the green light, then one second later, it cycles...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this will help in solving the problem....
Aug 09, 2011 | Pioneer PRO-730HDi 64 in. Rear Projection...
I have multiple colors on the screen of my 530hd pioneer elite TV when it warms up. When I try to adjust the convergence I am unable to move the red line far enough to converge on the blue or green line.
The convergence of your tv is defective try to replace it. You will find the convergence chip inside your tv, try to open the back cover of your tv but be sure to unplug the tv first. Try to look the large aluminum plate it is the heat sink, your convergence chip is attached to that heat sink it has a marking of stk-*** followed by a number you should remove it from the pcb using a soldering iron, and soldering pump but be very careful you might damage the pcb and may caused another fault to your unit. Or you can contact a service technician to save you from stress. Good day and best regards.
Jul 19, 2011 | Pioneer PRO-530HD 53" Rear Projection...
Pioneer elite pro-530hd tv---no picture at all!
Jan 19, 2009 | Pioneer PRO-530HD 53" Rear Projection...
Mr Bob
Sep 16, 2008 | Televison & Video
Power problems with PRO-530HD
need stk392-110 if that in it but i use stk392-120 you whant to ch restor by the ic stk392-110
Mar 30, 2008 | Pioneer PRO-530HDi 53" Rear Projection...
do you know what the pix look like be for it whent dead?
some time bad solder can do this. in the center of the board
thear is fuse that go bad because of bad solder on stk 392-120 or 110 on the conv. pcb the fuse is 5amp 125v you have about 3 of them on the def pcb. to ch them. to hit the flyback&hozoutput
ch cap.s in power supply.
Pioneer PRO-530HD
Its really hard to say if its a major problem or not. I think anytime a circuit part goes bad thats its a major problem, because these sets HAVE NO USER REPLACEABLE PARTS inside so you should call out a trained technician, as theres alot of High Voltage inside these sets and also this is not a place for an experimenter or a handi-person to be messing around in. Your problem if you are a tech and Know the HI voltage saftey issues is most likly in the standby or main power supply... Good Luck
Aug 05, 2006 | Pioneer PRO-510HD 53" Rear Projection...
Televison & Video Logo
405 people viewed this question
Top Televison & Video Experts
Electro Med Services...
